A-spec Oil Pan
Old Apr 30, 2007 | 10:33 AM
jskyline's Avatar
A-spec Oil Pan
Just want to know if anyone using the A-spec oil pan in here? my oil pan is leaking like there's no tomorrow. I'm looking for a long term fix. So beside that anymore suggestion? I know the oil pan bracelet is a pretty good fix. but i cant find it no where and the group buy doesn't have it anymore. Thanks for all the help.
Old Apr 30, 2007 | 11:21 AM
Mahjik's Avatar
Mr. Links
Those upgraded cast pans are generally not recommend for street cars. If they get damaged, they just crack open and dump all your oil. The stock pan will just dent.
If you have leaks, I would recommend just getting a new stock oil pan and then a brace from Gotham Racing or Garfinkle:
Gotham Oil Pan Brace
To be honest; if you buy a new pan and seal it properly, it will hold for MANY years. The problem most people run into is that their pan is all warped, therefor doesn't seal that well.
Old Apr 30, 2007 | 11:36 AM
jskyline's Avatar
I read somewhere in the forum said the gotham racing oil pan is nothing compare to the garfinkle one. is that ture? also what else i need to buy beside just the brace, IIRC i have to buy the oil pan stud kit right?
Old Apr 30, 2007 | 11:43 AM
Mahjik's Avatar
Mr. Links
The Garfinkle piece is nice, however they both get the job done. You can buy the extra hardware with the Gotham piece, it's listed on their site for an extra $25.
Old Apr 30, 2007 | 12:24 PM
jskyline's Avatar
Do i have to mill the engine mount? any clearance issue with the elbow hitting the strut bar? Sorry for that much of questions. These are the last question i have. Thanks Mahjik.
Old Apr 30, 2007 | 12:28 PM
Mahjik's Avatar
Mr. Links
No changes to the mounts or clearance problems with my Cusco strut bar. The only changes have to do with the engine mount and pan bolts/nuts. With the added space of the brace, new hardware is needed for those.
Old Apr 30, 2007 | 12:54 PM
jskyline's Avatar
Thanks for all the help. you answered all the question i have. Thanks mahjik
Old Apr 30, 2007 | 04:29 PM
dubulup's Avatar
development
if you use the stock strut bar and GReddy elbow with any oil pan brace you will need to mill the mounts down.
Old Apr 30, 2007 | 04:33 PM
BlueTII's Avatar
Banzai Racing
I use the Moroso stud kit from Summit, it is a much better then bolts for $20
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
