AEM EMS Area is for discussing the AEM Engine Management System!
AEM AEM EMS with Wideband part number????
Old Apr 29, 2007 | 07:13 PM
kovalev27's Avatar
I want to buy the AEM Ems with UEGO Wideband setup. I can only find the EMS and the UEGO Wideband seperately I want EMS and UEGO integrated. Anyone know what the part number is for that.. I heard it finishes with a "U" at the end of the part number.
Please help
Old Apr 29, 2007 | 07:19 PM
RX7Junkman's Avatar
it should be 30-4100
Old Apr 29, 2007 | 07:21 PM
kovalev27's Avatar
No see thats the thing I can only pull up that part number too. I want the EMS and EUGO integrated just like one for the EVO. I heard AEM made it for Rx7 too.
Old Apr 29, 2007 | 08:45 PM
fritts's Avatar
Mad Man
Next time try not to be an *** and think about what your doing. Don't post the same question in every forum section.
Old Apr 29, 2007 | 09:46 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
Originally Posted by kovalev27
I want to buy the AEM Ems.....
no, you don't.
Old Apr 29, 2007 | 11:24 PM
BoostCrzy's Avatar
Doritos on a toothpick
the AEM EMS for the FD works FANTASTIC!.....Tuning is the key...I have tuned quite a few with great results(stock twins and Single setups).... if you need any help or opinions ask me
~Jack
Old Apr 30, 2007 | 03:14 AM
point5chink's Avatar
what you need is a GOOD base map (which aem does NOT provide). You also need to learn about boost comp tuning. Those two things will make your experience with the AEM MUCH more enjoyable.
Old Apr 30, 2007 | 12:00 PM
kovalev27's Avatar
DEUCHE BAG... There's other ways of saying this... If you dont want to help just dont reply.... Let the forum Mod do his job like he did....
Old May 1, 2007 | 02:04 PM
kovalev27's Avatar
well between the haltech and the AEM. My tuner wants me to get the AEM. Once you know how to tune right it's so much bette then the haltech
Old May 1, 2007 | 11:37 PM
BoostCrzy's Avatar
tell your tuner i AGREE!!!! 100%
Old May 2, 2007 | 07:21 AM
Terrh's Avatar
I thought this EMS had unresolvable issues?
I've used an AEM for talons before and they're great for those cars, I'm pretty sure it's seperate problems that make them useless on an FD.
Old May 2, 2007 | 04:06 PM
that is entirely not true. There is one hardware bug where you must switch two wires for the throttle position sensor. Other than that, its all tuning. The base maps have a lot of errors, but if you fix those then its perfectly suitable. The AEM software really makes all of the other ems software look like toys in my opinion.
Old May 3, 2007 | 08:15 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
on paper nothing can touch the AEM EMS.
map switching
active knock ignition/fuel control
traction control
individual injector control
etc etc, and there are tons of etcs...
that's on paper. the overall FD/AEM relationship has been a train wreck. perhaps this is because the unit requires that your fill in all the blanks. we do know that the AEM works well on other apps... so it should work on the rx7.
we also know that some of the other AEM prods have significant flaws... such as the CDI module.
i recently bought the FJO injector driver convertor over the AEM because of just this consideration.
as to the primary question posed: i do not believe that the AEM EMS for the FD PN 30-1800 is made in a "U" configuration.
i am still considering the AEM...
howard coleman
Old May 16, 2007 | 12:18 PM
BIGWILLRAT7's Avatar
BIGWILLRAT7
if you want the ems universal with the uego part numbers is 30-1900u you cant get a plug and play with the uego you have to buy part number 30-1800 thats the plug and play only for 93-95 and if thats what you want you have to buy a uego seperatly the part number is 30-4100
Old May 17, 2007 | 03:56 AM
tcb100's Avatar
DinoDude
The AEM works pretty well in the hands of a tuner who knows what he is doing. Ray Wilson at PFS installed mine, tuned the car, and reported no difficulty related to the unit. There is no longer a problem with the TPS.
The biggest problem is that the doumentation and manual are impenetrable. Why they have not improved it is beyond me. Tech support does come on line quickly to answer questions.
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
josef 91 vert
23
Sep 3, 2015 11:20 AM
