Quick PS question, please help!
Old Mar 24, 2002 | 02:47 PM
Snufelupogus's Avatar
Do I Really Exist?
Question Quick PS question, please help!
I know the topic of power steering removal have been over done, and YES I have done a search for it. So far what I have been told is that you loop the two tubes together so that the fluid can pass through with the pump removed. But what I dont understand is WHICH two tubes Im supposed to be looping together... Cause I look at the pump and there are 3! Two pressure lines, and a return line (that is like 50 feet long for reasons I cant figure out...).
So if someone could tell me quick, which of these two lines do I connect together and what am I supposed to do with the third line?
Thanks
Old Mar 24, 2002 | 05:07 PM
Do I Really Exist?
bummmmmmmmmmmp
Someone has to know this. I know you guys have done this before...
Old Mar 25, 2002 | 11:48 PM
Do I Really Exist?
I cant believe that no one knows which lines Im supposed to connect here... geez
Oh yeah, TTT
Old Mar 25, 2002 | 11:55 PM
I wish I was driving!
I'm having trouble picturing the lines you are talking about.
There are two lines leaving the rackin the rack. Connect those two lines together.
Remove the pump and all the other bs up top, and the cooling loop.
Thats it.
Old Mar 26, 2002 | 12:36 AM
bcty's Avatar
Boost This!
this would be the best thing ever!! i have my pump removed but i dont know how to take it out!! could someone post a pic of the whole unti and maybe circle with paint the parts and what we need to do with it!! that would be sweet!!!!! thank you
Old Mar 26, 2002 | 12:55 AM
You have the pump removed, but don't know how to take it out?
you mean you have the pump disconnected.
Take of the front pulley, and take off the bolts behind it (if you still have the a/c).
do you have A/c?
Old Mar 26, 2002 | 12:59 AM
bcty's Avatar
Boost This!
sorry i have it dissconnected... and the a/c is gone... go on....
Old Mar 26, 2002 | 01:07 AM
well, if the pump is disconnected, take out the fuse to the p/s pump, and then undo the five nuts and bolts to the a/c and p/s bracket
Bracket and pump will come offf. That's it.
Sean
Old Mar 26, 2002 | 01:12 AM
bcty's Avatar
Boost This!
but there are lines and **** going to it what the hell do i do with those? and all the hard lines!! thats why i need a pic im really confused
Old Mar 26, 2002 | 01:18 AM
oh, you just have the pump belt off?
Take off the pump, the bracket, and all the lines, All of them that have any connection to the p/s pump.
Now, take the two lines that come out of the p/s rack. Take the ends of them, and splice them together.
Steering should be easier than it is now, since now your rack can equalize its side pressures. With just the belt removed, steering will be the Hardest.
try this write-up (a little sketchy) for some help:
http://2ndgenrx7.freeservers.com/techmaster.html
click on p/steering removal, under how-to's on the left
Sean
Old Mar 26, 2002 | 09:55 AM
Do I Really Exist?
Thanks, that site is sweet, added to my favs list
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
