Messed up accessories
Old Mar 24, 2002 | 12:02 PM
Fingers's Avatar
Hey guys,
My alarm works intermittently, my horn works intermittently, WTF!!!! I think its the cold solder CPU problem... but i'm not too sure... Has someone performed this mod? Did it work? Do you have DETAILED pics or tips? Also, sometimes when i get into the car... the damn seatbelt light is glowing... without even having the key in the ignition. Perhaps its related. Anyways, thanks!
-Ross
Old Mar 24, 2002 | 01:57 PM
Aaron Cake's Avatar
Engine, Not Motor
Cold solder joint problem in CPU, logicon and idiot light cluster. Search the Net for the 2nd gen FAQ. You will find detailed instructions and pictures there.
Old Mar 24, 2002 | 01:58 PM
Tree's Avatar
Re: Messed up accessories
Does it glow really faint? If so mine does that too sometimes, but I don't have any problems with the alarm working intermitantly., so they might not be related. I not sure that I've ever used to horn, so I don't know about that...
Old Mar 24, 2002 | 02:45 PM
RETed's Avatar
Throw that POS stock alarm away.&nbsp The horn problem is definitely a "CPU" problem.
-Ted
Old Mar 24, 2002 | 03:09 PM
Fingers's Avatar
Dont worry RETed i got an aftermarket alarm too... but it's always good to have a backup... even if it's an intermittent POS
Thanks for your reply, however.
-Ross
Sethix
Nov 3, 2017 11:48 PM
Robrods64
Oct 2, 2015 07:56 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
