how does the freakin eshaft come apart?
Old Apr 19, 2007 | 09:54 PM
patman's Avatar
Resident Know-it-All
hey guys i cant figure out how to get the center rotor housing apart, do i have to take the eshaft apart and if so how do i do it?
thanks
Pat
Old Apr 19, 2007 | 10:16 PM
kenn_chan's Avatar
Savanna Rx-7
20b or 13b/12a ?
12a/13b with the motor suspended (via milk crate, engine stand adapter plate etc.) you lift the e-shaft about 1" and then lift and wiggle the center plate past it, make sure not to scratch the bearings.
20b use the special tool to seperate the front portion of the e-shaft, once you have it off the center adapter plate comes off. form there you trteat it like a 13b/12a.
kenn
Old Apr 19, 2007 | 10:19 PM
patman's Avatar
special tool? i will have to make one, what holds the shaft together?
Old Apr 19, 2007 | 11:41 PM
RoTaRyBoYz's Avatar
InsaneRotaries.com
i think scallywag (sp?) made a few of these tools, maybe u can PM him... the eshaft is a 2pc design and its held in by the taper of the 2 pcs fitting into one another..i know some guys got it seperated a few times using some 2x4 wood..if u cant buy the tool from one of these guys and not in the mood to make one then PM "Spanner", he used the wood method with success..i tried looking for a pic of the tool, but i must of deleted it from the PC
Old Apr 20, 2007 | 12:14 AM
GtoRx7's Avatar
Collections Hold
Its identical to how the flywheel is held on.
Old Apr 20, 2007 | 06:33 AM
patman's Avatar
so it is just press fit with a key? i should be able to get that apart...
thanks guys
Old Apr 20, 2007 | 08:07 AM
patman's Avatar
wow that was freakin easy...took me all of 15 seconds once i knew how it went together. plus i got to use my favorite tool (BFH )
thanks guys
pat
Old Apr 26, 2007 | 09:10 AM
patman's Avatar
Ok i got a PM about this, so for future reference if anyone else wonders, the journal for the front bearing slides onto the shaft with a key. to get it off, screw the nut back onto the front of the eshaft a few threads, and simply pull on the front bearing journal and tap the nut with a hammer. The journal should pop right off.
Old Apr 26, 2007 | 03:09 PM
C. Ludwig's Avatar
www.lms-efi.com
How did we ever survive without the internet?
Old Apr 26, 2007 | 05:58 PM
ReZ311's Avatar
KM48 Burnout
Here are teardown pics of my 20B a while back with brief descriptions.
http://www.rotaryheads.com/2nd-gen-r...or-rx7-p3.html
lduley
65
Feb 26, 2016 06:09 AM
Sterling
27
Jan 4, 2002 11:21 AM
