Ports 5 and 6 Help
Old Mar 23, 2002 | 01:52 PM
87GXLRX7's Avatar
Ports 5 and 6 Help
I know many messages have been posted, but i can't find any of them, what is the procedure for wiring my 5th and 6th ports open. thanks for the help
Old Mar 23, 2002 | 02:47 PM
Aaron Cake's Avatar
Engine, Not Motor
Talking
How about not wiring them open? Your car will loose all it's low end, and will actually be slower than if the ports were working properly.
Old Mar 23, 2002 | 03:41 PM
XLR8's Avatar
The 6 ports actuators are located above the exhaust manifold. Two round shells with an arm on the upper end. The problem with the 6ports is they get carbon in them throughout the years and don't function properly. Since they are operated by backpressure from the exhaust, if you have an open exhaust they will not work properly. To check them, smear a little grease on the arm, take it for a spin, and see if the grease is altered. Note the rods push into the shell when they open.
I wired mine open for awhile with zipties around the shell and accross the compressed arm. Strong ties will work and not melt.
Wiring them open will slightly effect your low end. I only saw a slight difference in low end, and when open a nice difference in topend.
Old Mar 23, 2002 | 03:46 PM
rico05's Avatar
WTB S5 N/A FC
I did mine, and I have a high flow exhaust (N1 muffler, RB header, presilencer) and I really like it. I can still light up my tires off the line. Now simple stop light to stop light driving is a little less powerful, but top end is sooo much sweeter.
Old Mar 23, 2002 | 03:52 PM
Aaron Cake's Avatar
Engine, Not Motor
You will only see a top-end improvement if your ports are not working properly in the first place. Therefore, the best solution is to get them working properly, so you have the advantage of both good top end and low end power. Fix the problem, instead of bandaging it.
Old Mar 23, 2002 | 05:34 PM
von's Avatar
von
I say get rid of them or glue in the racing sleeves. Bitch.
iamsisyphus
Sep 27, 2015 01:42 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
