Haynes Guide doesn't help
Old Mar 22, 2002 | 06:24 PM
Vroomaster's Avatar
I'm trying to locate the ECU, Haynse pic looks like it's in the floor, under the carpet. I can't see it under the dash, so is it under the car or what?
ps, I did do a search, but no location hints....
Old Mar 22, 2002 | 06:33 PM
91vert's Avatar
It is under the carpet where your passenger's feet would be. Just pull the carpet back up by the firewall and you will see it.
Vroomaster's Avatar
cool, thanks
brown wire, black stripe, here I come.....
Old Mar 22, 2002 | 07:24 PM
Vroomaster's Avatar
I see a couple of brown wires w/ black stripes, which one do I ground?
Old Mar 22, 2002 | 07:37 PM
Turbo Timmy's Avatar
Professional Lurker
Confucious says...
Installation is the reverse of removal.
Old Mar 22, 2002 | 07:46 PM
Vroomaster's Avatar
So, do I ground all brown wires w/ black stripes, or is the one I'm looking for in a peticular bundle?
-tryin to fix 3800 rpm problem
Old Mar 22, 2002 | 08:27 PM
Vroomaster's Avatar
Old Mar 22, 2002 | 08:58 PM
Vroomaster's Avatar
Old Mar 23, 2002 | 02:09 AM
HAILERS's Avatar
HAILERS
Try this site by RXSTER http://ourworld-top.cs.com/flrxster/ECU.html
Old Mar 23, 2002 | 02:18 AM
HAILERS's Avatar
HAILERS
Here's a jpg of the three plugs of the ECU. Its a view looking straight into the ECU. They label things from right to left. Above the plugs is a readout of what the pins do in life. I think I'll scan the other two pages and send them to you also.
Old Mar 23, 2002 | 02:24 AM
HAILERS's Avatar
HAILERS
Second jpg
Old Mar 23, 2002 | 02:26 AM
HAILERS's Avatar
HAILERS
And third. You can look at the printout of the control unit and see that the grounds are 3G, 3A, 2R, 2C if that helps any.
Old Mar 23, 2002 | 02:42 AM
HAILERS's Avatar
HAILERS
Here is a schematic of some of the sensors. You're right to want to ground the brown/black wire(86 and 87 model cars). You can see how its all spliced together to the tps,boost sensor, airflow meter, air intake sensor, water thermo sensor, variable resistor etc. It terminates at pin 2C on the ECU. There is a ground for the ECU under the dynamic chamber. Its a round connector lug with about three ground wires. What your doing seems plenty good fine.
Old Mar 23, 2002 | 07:58 AM
Vroomaster's Avatar
Thanks HAILERS! I'll update when complete, I'm also changing fuel filter and coolant today so It'l be a bit.
Old Mar 23, 2002 | 10:15 AM
Vroomaster's Avatar
Ok. in the guide to HAILERS 1st link, it says "The ECU, located in the passenger side footwell, has three gang plugs in it. On the smallest plug there will be four green wires (with various color striping) for the injectors, and a solid black wire (among others). This black wire is crimped (poorly, with no insulation) to three smaller black wires about 2" from the plug. "
When I get into the small bundle, the black wire is not crimped into the 4 green wires. Should I connect them? the scematic (HAILERS last attachment) doesn't show they should be connected. I'm thoroughly confused.
Old Mar 23, 2002 | 10:25 AM
Vroomaster's Avatar
Ok, looking at it more, I see that the black wire is a ground that goes to the body, and that the injectors are activated by ground pulses, so I think this will be ok, but would like confirmation for peace of mind (and my ECU's) heh. Thanks anyone.
Old Mar 23, 2002 | 11:21 AM
Vroomaster's Avatar
sorry this is so long, but don't want to blow my ECU. There are 2 black wires 3G & 3A, do I attach them both to the 4 green wires (injectors)? Anyone care to take a shot at this?
Old Mar 23, 2002 | 11:40 AM
HAILERS's Avatar
HAILERS
No don't do that. He really just observed that there were some green wires with stripes. He shoulda maybe left that remark out. He is just grounding the black wire and mentions how if you follow it from the ECU plug up the harness you will find there is a spliced area with some other ground wires. Yeah, whatever you do don't ground the green wires. The ECU pulses a ground to these wires to turn the injectors on and off. I think you already figured that out though.
Old Mar 23, 2002 | 11:47 AM
HAILERS's Avatar
HAILERS
VROOMSTER, DONT USE THE RXTER POST TO DO YOUR GROUNDS. ITS FOR A LATER CAR. YOU SHOULD BE GROUNDING THE 3G, 3A,2R,2C GROUNDS. PM ME RIGHT AWAY.
Old Mar 23, 2002 | 11:48 AM
Vroomaster's Avatar
OK, I see, should I ground both solid black wires on the small bundle?
Thanks for responding btw! Newbies like myself would be fryin our ECU's otherwise!
Old Mar 23, 2002 | 12:09 PM
HAILERS's Avatar
HAILERS
MY fuckup. RXSTER'S got a good write up but for another series. His breakout plug is really nice too.
Old Mar 24, 2002 | 09:02 AM
Vroomaster's Avatar
Grounding those 4 wires made my idle rock steady at 750, it was varying about 100-200 prm back and forth slowly, it also make the car run much smoother it seems. Didn't solve my 3800 hesitation though, hmpffff.
Old Mar 24, 2002 | 09:23 AM
HAILERS's Avatar
HAILERS
Seeing as how this is an electrical weekend for you, why not go ahead and try adding a extra ground to the brown/black stripe wire on the boost/pressure sensor and do like Six Rotors did on his car and even add and extra one at the tps. Worth a try and not much bother. Try checking resistance b/t the brown/black wire on the boost sensor and the negative terminal on the battery. I think it should be .1ohm or less with the key turned off. Might double check the ground wire from the battery to the chassis and where it bolts on the starter bolt.
ArmAnirx7
West RX-7 Forum
35
Mar 8, 2021 12:54 AM
Captain Hook
13
Oct 4, 2015 06:35 PM
Robrods64
Oct 2, 2015 07:56 PM
