Greddy New style front mount kit
Old Mar 22, 2002 | 05:35 PM
I know a few people have had a problem with this kit, making it fit specially at the throttle and power steering pump area.
I've seen the picture of someone's blue vert that modified it to make it work.
Just curiuos if anyone had any problems or modification to make it work.
The only way I can make it fit ok is if I get a 45 degree elbow hose at the throttle adapter and pipe area and make the pipe bend up a little. I still cann't get the pipe to clear the power steering pump so It looks like i'm going to have to remove it. If i dont' do the 45 degree bend it will hit the master cylinder.
Anyone with this problem.
C
Old Mar 22, 2002 | 05:44 PM
cymfc3s's Avatar
I Raise Chickens
you need to take the elbow to a welder and have him section it with some compound turns. Basically so the elbow "S's" around the master and still hugs the shock tower.
Old Mar 22, 2002 | 07:03 PM
I know what you mean, kind of what someone with the vert did.
Hmm. I'll take some pictures tommorow and show my idea using a 45 degree elbow.
C
Old Mar 22, 2002 | 07:14 PM
cymfc3s's Avatar
I Raise Chickens
if you can get it clear the hood ok, id like to see how you did it.
Old Mar 22, 2002 | 07:35 PM
Turbo Timmy's Avatar
Professional Lurker
Who's got this for sale the cheapest?
Old Mar 22, 2002 | 08:11 PM
I got mine from horsepower freaks, I got the 24 row one, around 974 plus shipping i think.
The bend actually clears the hood but I can 't use the power steering pump.
I wonder how it would work using the bend goign downward? I'm going to try that tommorow
C
Old Mar 23, 2002 | 02:11 PM
Anybody have the instructions to install the FMIC kit from greddy that can email it or fax it to me. The person I got it from can't get greddy to fax it to him.
The installation looks easy but I have a bag of crap like bolts, nutz and pieces of metal that I have no ideal where they would go. The instructions would help. I'm willing to compensate you for any trouble.
C
Old Apr 4, 2002 | 10:45 AM
Here is a pic of the 45 degree elbow at the throttle body.
Old Apr 4, 2002 | 06:51 PM
Professional Lurker
nice! I was going to get mine from horsepowerfreaks since they are so cheap... how long did it take to get yours?
Old Apr 4, 2002 | 07:22 PM
Got mine from horsepower freak. I think it took 2 weeks.
Becareful which one you get, the v pec is for the stock turbo and the r spec for the greddy turbo upgrade.
I by mistake got the r-spec and had to do some more modification to make the turbo side work.
C
Old Apr 4, 2002 | 08:24 PM
Professional Lurker
hmm i'm gonna be running a hybrid with a t04 compressor which one should I get?
Old Apr 4, 2002 | 08:32 PM
streetpower's Avatar
I simply cut the piece that went between the p/s pump and the brake master..switch it around connected it with a silicone hose and sought of slightly flattened it to make it fit...it still rubs a little but i think a torqu brace may limit the movement.....this is on the r spec model....
Old Apr 5, 2002 | 09:33 AM
The vpec will hook normaly to the stock location of the turbo, even if you are running a hybrid.
Thats' what cymfc3s kit has but he has the 32 row IC.
I got the 24 ic and fit ok. i had to trim the bumper at the bottom a little bit but no bulging.
C
Old Apr 23, 2002 | 11:01 AM
Finally, PS back.
Finally, got power steering back.
I had to upgrade to the smaller power steering pump offered on 88s and up. I had the big *** pump from the 86-87s which wouldn't let me pass the IC pipe next to it. Here is a pic.
There is about 3/4 inch clearance agaist the shock tower and using the 45 degree angle joint hose at the throttle. Had to bend the power steering lines a little to make it fit.
C
Old Apr 23, 2002 | 01:41 PM
cymfc3s's Avatar
I Raise Chickens
looks good man. I need to do something similar to that for my black FC which has power steering.
Old Apr 23, 2002 | 01:57 PM
jmseven's Avatar
Asset is Wealth
Damn, that is a tight fit.
What is that braket on the pipe for?
Old Apr 23, 2002 | 02:02 PM
cymfc3s's Avatar
I Raise Chickens
the bracket goes the power steering bracket, but that pipe doesnt quite work on a us-spec car.
Old May 22, 2003 | 12:13 PM
What Greddy Kit are you guys referring too? The 24 Vspec or 24 Rspec?
Thanks
rotor_veux
46
Jun 12, 2018 10:39 AM
Marty RE
Aug 13, 2015 11:19 AM
