idle at 1000rpm when it is cold
Old Apr 9, 2007 | 10:08 PM
v8huntr's Avatar
hello,
today, i finished the single turbo install and started up the car with out ic pluming connected to turbo. car started right up but it idles at 1000rpm even when it is cold. Will the cold idle bump up when i connect IC pluming? I have made lots of change and not sure what could be the problem.
list of mods
1. single turbo kit.
2. fuel system
3. PFC
4. everything blocked off except wax warmup and cold idle motor.
thanks
Old Apr 10, 2007 | 07:39 AM
dubulup's Avatar
development
don't try to set idle until all plumbing is connected.
Old Apr 10, 2007 | 10:44 AM
v8huntr's Avatar
Will it idle low without pluming? I'm not going to set the idle now, just wanted to know if it is normal for rx7 to cold start and idle at 1000rpm. before it would bump around 1400 and come down to 800 or so with complete pluming. now without the pluming it idles around 1000 when it is cold.
mikedscpt
22
Oct 28, 2015 03:04 PM
xXBrendanXx
Power FC Forum
Sep 17, 2015 10:10 AM
Monsterbox
Sep 11, 2015 03:29 PM
RotaryBobby
Sep 10, 2015 01:33 PM
The1Sun
Sep 7, 2015 10:21 PM
