Car in shop now, Transmission questions!
Old Mar 22, 2002 | 09:15 AM
Deathbots's Avatar
OK so my 86 GXL is in the shop. The trans had to be rebuilt, and after it was rebuilt it started making an awful lot of noise. luckily for me, it's under warranty and the garage is honoring that warranty.
Anyway, they want to start all over with a new trans. Not new necessarily, just a different transmission. I know that later transmissions were much stronger (89+, say a GTU model)
Will one of those fit on my car with no modifications?
if so, I can tell the shop to look for one of those and I could get rid of the notoriously weak 86 NA trans.
Old Mar 22, 2002 | 10:57 AM
hypntyz7's Avatar
The 89-91 5sp will bolt up no problems as long as you have the 89-91 crossmember to go with it.
FWIW I have one with a bad 5th gear synchro Ill sell for $100. It drove adn run great other than grinding each shift to 5th.
THe 89-91 trans. is not any stronger than the 86-8 AFAIK.,
Old Mar 22, 2002 | 11:02 AM
hIGGI's Avatar
TII trannys are stronger, but to use it on NA you would need TII flywheel and clutch....that setup is in my car right now, NA engine, TII clutch, tranny, diff etc...
Old Mar 22, 2002 | 11:41 AM
Deathbots's Avatar
Thanks for the responses-
hypntyz7:
Unfortunately for you the trans shop is replacing everything under warranty. So I pay nothing!
higgi: I don't have deep enough pockets for a TII flywheel and clutch. oh well!
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
pjr
Aug 12, 2015 12:22 PM
