Sheet of flat plastic?
Old Mar 21, 2002 | 11:13 PM
Ryde _Or_Die's Avatar
Does anyone know where I could get a piece of flat plastic to cut out places for my electronics? Thanks alot.
Old Mar 21, 2002 | 11:17 PM
RETed's Avatar
Any color or thickness in particular?
I believe Parts Express (http://www.partsexpress.com/) has ABS sheets in 12"x12"x1/8" black squares.
-Ted
Old Mar 21, 2002 | 11:43 PM
-Ted
Wouldn't really know since this would be my first time doing this. Thanks for the link though. I want to put my turbo timer, boost controller and fuel controller in where the stock radio is. I think it seems easy enough. What do you think?
Old Mar 21, 2002 | 11:54 PM
RETed's Avatar
I just checked McMaster-Carr (http://www.mcmastercarr.com/), and they have a larger selection of ABS sheets.
Check "Raw Materials and Springs" and "Thermoplastic" and click on "ABS".&nbsp You can choose size, thickness, and color (beige or black).
Yes, I normally work with ABS plastic.&nbsp It's pretty easy to cut (run as low as a blade speed you can), and it's pretty durable.
-Ted
Old Mar 22, 2002 | 12:20 AM
Sniper_X's Avatar
Any hobby shop....
should have what your looking for.
Check Home depot, look for things that have large amounts of plasic IN them or are MADE OF large sheets of plastic.
A door, or plexiglass (back painted black) or whatever.
Old Mar 22, 2002 | 12:40 AM
RotaryMiata's Avatar
I think if you're going to use the stock radio (single DIN) hole, then you should get one of those $15.00 installation kits and use the flat blocking panel from there: no cutting, perfect fit first time!
If you can't find one, any hardware store will have a sheets of Lexan that you can work with. Hell, if you wanted to be ricey, you can always use the neon yellow!
Good luck!
Old Mar 22, 2002 | 12:46 AM
BLUE TII's Avatar
Rotary Motoring
I use aluminum sheet metal and black textured paint over it. The black textured paint really looks at home in the FC interior.
Old Mar 22, 2002 | 11:45 PM
RETed's Avatar
Re: Any hobby shop....
I do NOT recommend using plexi - it's a bitch to cut (cracks really easily) and scratches even more easier!&nbsp Plexi also gives off noxious gases when heated and warps easily in a hot interior.&nbsp ABS is superior to plexi with the exception that it's hard to find "clear" ABS.
-Ted
Old Mar 23, 2002 | 12:05 AM
Bambam7's Avatar
I came, I saw, I boosted.
Any comprehensive car audio shop will have ABS. I can always get leftovers and such, I have made a few stereo surrouds, etc with it.
Old Mar 23, 2002 | 12:23 AM
TRUDSL's Avatar
there is some stuff in a place called Lowe's near where i live (not sure if ppl are familiar with it) but they sell the high impact plastic that comes in 1/4" thickness. just paint the back part of it the color you desire and it comes out sweet. trust me.. you have a jigsaw and a dremel, thats all you need.
Old Mar 23, 2002 | 12:31 AM
crasher2's Avatar
what are you trying to do with the plastic,
Old Mar 23, 2002 | 01:10 PM
fcturbo2's Avatar
Doesnt BLITZ sell the same thing except better??..they have one that holds 2 controllers and 1 gauge not sure if its for 52mm though..I dont know if they fit fc or fd.
Old Mar 23, 2002 | 02:41 PM
FC Drifter's Avatar
Damaged Little F*cker
what about carbon fiber? where could one find carbon fiber sheets or whatever to use in the same place?
Old Mar 24, 2002 | 04:21 AM
BLUE TII's Avatar
Rotary Motoring
www.roadraceengineering.com/rock/tunerpods.htm
Has flat CF panels and panels w/ molded edges available as well as guage pods. Megaspeed7 posted this address in the TMIC thread for the CF hood vent.
Old Mar 24, 2002 | 08:43 AM
How hard is it to cut CF though? Also what would work best to cut plastic even? Thanks alot.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
MidnightOwl
Sep 25, 2015 10:24 PM
