Afterburner sound at 80-85ish MPH?
Old Mar 21, 2002 | 05:03 PM
WonkoTheSane's Avatar
Green Flameless
I have my 86 GXL NA that i was able to put back on the streets after a bit of work.. the major problem i have with it now is that after about 40 mph, it starts to shake and vibrate... it gets slightly worse the faster you go, but the real fun is when you hit about 80.. there's an EXTREMELY loud sound, it appears to come from the rear of the vehicle.. it sounds like the car forgot it had mufflers. Once you hit about 87-90ish it resumes it's normal vibration noises.. Now, a friend of mine recommended that i look at the rear struts and replace the rubber sections of the engine mounts, and that should take care of the vibration, i'm just wondering if it will indeed fix most of the vibration and the loud sound? It's a fun car, and it'll be a pretty sweet ride if i can bear to sit in it w/o my *** falling asleep
Thanks!
Old Mar 21, 2002 | 08:01 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
Wonko?
Are you the same wonko as on everything2?
Old Mar 21, 2002 | 09:50 PM
Gene's Avatar
10 lb. boost, 5lb. bag
I wonder if the wheel bearings are bad...
Old Mar 21, 2002 | 11:11 PM
Green Flameless
Terrh- nah, i'm not wonko on there *old man voice* Back in my day, when i first got on the net, a infoseek search (the cool search engine of the time) for Wonko The Sane only turned up 3 refs, one was my old homepage and two were douglas adams refrences! </end oldmanvoice>
Gene - you think that would cause the vibrations? I guess it sounds plausible Thanks!
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
Thor 18
Sep 28, 2015 07:35 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
Casual_John
Canadian Forum
Sep 26, 2015 01:47 PM
