Sponsored by: CARiD
87 FC (s4) tune up?
Old Apr 3, 2007 | 06:13 PM
Rotary_Powerd's Avatar
87 FC (s4) tune up?
Hi! Just bought an S4, It has 83,500 miles on it. I want to give it a good tune up but don't know where to start. Does anyone have any suggestions please.
Old Apr 3, 2007 | 07:23 PM
HeyITZthatFC's Avatar
fc3s
You can look for these things in the search bar, theres a lot of of threads about giving tune ups, tune ups are changing oils (motor, tranny, diff, clutch), checking tired pressure, alignment, grounding, etc etc..
Old Apr 4, 2007 | 09:46 PM
Thanks. I didn't see any specific stickies, I've poke around a bit so i'm guessing:
-oil change
-differencial oil change
-Tranny oil change
-clutch oil change
-coolant flush and fill
-new plugs and wires.
-new fuel filter
anything else?
Old Apr 4, 2007 | 09:58 PM
LovMyRx7's Avatar
Rotary Inspired.
You should purchase SpooledUpRacing's tune up kit...
Old Apr 4, 2007 | 11:32 PM
Cool how much $$$, and where do I get it?
Have patience with the newb.
Old Apr 5, 2007 | 10:27 AM
Chuck's Avatar
In addition to the fluid and plug changes, you should also check the function and setting of the throttle position sensor (see the factory service manual in the 2nd gen FAQ), and you should also check and adjust timing. Once these are done, go back and adjust idle speed to 750. Check compression. Replace the Oxygen sensor; Replace the thermostat (RX-7's hate high temps). Check the vacuum lines and replace ones that are old, worn or cracked.
Old Apr 5, 2007 | 09:06 PM
Thanks! That's very helpful.
Old Apr 7, 2007 | 06:58 AM
RETed's Avatar
Look in the owners manual.
-Ted
Old Apr 7, 2007 | 09:12 PM
Just bought the hynes.
Old Apr 8, 2007 | 10:32 PM
Needs a little body work and it'll be ready to go
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Andrew7dg
Aug 6, 2017 01:41 PM
demetlaw
Oct 2, 2015 06:22 PM
93FD510
Oct 1, 2015 02:00 PM
