Microtech 13b-re swap question
Old Apr 1, 2007 | 08:08 AM
RotaryBuddha's Avatar
CURVE OF CONSTANT WIDTH
Ok so I've been thinking about going from the 13bt to a 13b-re. I know I want to ditch the twins and go with a GT40 or that Aspec 500R. I know this will involve taking the water pump and front cover off my 13bt to put on the 13b-re. But what I'm wondering is if I can still use my microtech that was programmed for the 13bt. Basically I'm asking if some of the sensor read the same or if I can transplant them to the 13b-re, like the CAS for example? Or do I have to send it off to mircotech to be reprogrammed like if you want to use it for a 13b-rew?
Old Apr 1, 2007 | 10:21 AM
Aaron Cake's Avatar
Engine, Not Motor
Sensors are the same. I think the RE CAS is the same as the FC CAS, but worst case you can swap the FC CAS on.
Old Apr 1, 2007 | 04:41 PM
Thanks aaron so this is pretty much a straight swap. According to everything I've read so far.
Old Apr 6, 2007 | 01:28 PM
Jon Goodwin's Avatar
Use the 13bt front cover complete, and modify/remake centre plate engine mount.
John
Old Apr 8, 2007 | 10:27 AM
^I know about the front cover. And I was going to use these front the engine mount.
http://www.banzai-racing.com/2nd_gen...e_brackets.htm
Old Apr 11, 2007 | 07:36 AM
Sindregutt's Avatar
Im starting my 13bRE in my s4 today with a s4 frontcover, CAS and LT8 set up for s4 13bt.
It should work fine. The TPS is different (4pins insted of 3) but one of them are only N/C
Old Apr 11, 2007 | 08:07 AM
^let me know how it goes
Old Apr 11, 2007 | 04:45 PM
Sindregutt's Avatar
I fired it up today! What a great feeling having my first build running with no problems. Some small leaks but thats easy fix..
Specs are:
13bRE (20 000km), fresh rebuild, exhaust ported, gt35r, lager injectors and the LT8 with a S4 CAS worked great!
Sindre
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
RotaryBobby
Aug 29, 2015 10:32 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
