Searched but not the answer I wanted --Spark PLug Q
Old Mar 21, 2002 | 09:31 AM
RavenRx7's Avatar
It's about to be at that 20k marker and time for spark plugs. Take a look at my mods and suggest the plugs you would use....also if i took it to the dealership would is the norm charge? and how hard is it the due it your self? Thanks
Old Mar 21, 2002 | 09:39 AM
JBC's Avatar
JBC
I have heard that it is good to change them every 10k or so depending on how hard you drive the car. I would still stick with the stock plugs 7's in front 9's trailing.
FYI-I would avoid the Mazda dealerships if I were you. I have personally had bad experiences with them.
Old Mar 21, 2002 | 09:40 AM
vudoodoodoo's Avatar
Yeah, the Mazda dealers techs don't know **** about RX-7's.
Old Mar 21, 2002 | 09:41 AM
RavenRx7's Avatar
thats what ive heard --- i guy before said that the dealership couldnt even find them... what do you mean 7 in front --and 9's trailing...two different sizes?
Old Mar 21, 2002 | 10:06 AM
Salguod's Avatar
Each Rotor has a leading plug and a trailing plug. For stock setups, they are different in heat range.
For your setup stick with the stock NGK plugs.
BUR7EQP - Leading - lower plug of each rotor.
BUR9EQP - Trailing - Top plug of each rotor.
Its pretty eacy to do yourself. Just do one at a time so you dont mix anything up (disconnect only one spark plug wire, and remove only one spark plug at a time).
The lettering is on each plug, so just put the matching new plug back in the matching hole.
http://www.racingbeat.com sells them the cheapest I've been able to find at $8.25 each.
Good Luck.
Old Mar 21, 2002 | 10:08 AM
RavenRx7's Avatar
thanks a bunch for the information.....wish me luck
Old Mar 21, 2002 | 11:32 AM
RavenRx7's Avatar
Arrow
Is there anyway somebody can supply me with a pic of spark plugs.. so i can see which one is the lower and top... thanks
Old Mar 21, 2002 | 11:38 AM
KibagamiR2's Avatar
From: So farrrr away from the Land of the Rising Sun
Hmmm... I bought my NGKs at a dealership here in Atlanta for 7.75 each. Naturally each dealership has their own prices.
-Kib
Old Mar 21, 2002 | 11:49 AM
rynberg's Avatar
BTW, didn't see an ecu, upgraded fuel system, or intercooler in your mods. You are going to blow that new engine running a full open exhaust like that.
Old Mar 21, 2002 | 11:52 AM
RavenRx7's Avatar
I rally dont get on it that much, but i will by the APexi PFC soon
Old Mar 21, 2002 | 11:53 AM
RavenRx7's Avatar
autozone will have these right?
dkwasherexd
May 27, 2017 04:51 AM
20B Forum
Aug 18, 2015 02:46 PM
