Partial Bridge FC
Old Mar 21, 2002 | 02:04 AM
BlackTurbo2's Avatar
Partial Bridge FC
Well Tonight me and my buddy Andy just finished puttin in his Half Bridge ported motor. It was our first time building a motor, none the less bridgeporting it. We spent 4 hours puttin it in and.....It started right up!!
At about 1500 RPMs it was real steady, but wouldnt idle. We just have to tinker with it, but DAMN!!! Such a good feeling!!! Just thought Id share it with you all!!!
I'll have some pics and possible some Sound bites later!!
Old Mar 21, 2002 | 03:04 AM
here a couple:
Old Mar 21, 2002 | 03:05 AM
engine bay
Old Mar 21, 2002 | 12:19 PM
What sort of set up is it? and have you driven it yet?
Old Mar 21, 2002 | 12:30 PM
Rotortuner's Avatar
Undercover
So what kind of intake are you guys using and also i take it that this is an old pre 85 4 port right? Any ways looks good and ya we wanna here how it drives.
CJG
Old Mar 21, 2002 | 12:31 PM
SureShot's Avatar
Seduced by the DARK SIDE
I hope you left enough metal to suport the corner seals and O-rings.
Old Mar 21, 2002 | 12:33 PM
peejay's Avatar
Old [Sch|F]ool
Re: Partial Bridge FC
I think 1500 *is* where idle speed should be...
Big ports are cool...
rotortuner... those are definitely '86-up housings, note the coolant seal grooves are in the side housings. '85-earlier engines are smooth there, and the grooves are in the rotor housings.
Old Mar 21, 2002 | 12:35 PM
Rotortuner's Avatar
Undercover
check teh pic above. You can see that it doesn't even get close to the water o rings. And there is a good amount on the bridge there too. Looks good.
CJG
Old Mar 21, 2002 | 08:36 PM
Angel Guard Racing Team's Avatar
The rotor housing will cover half of the bridge.
Old Mar 21, 2002 | 11:32 PM
RETed's Avatar
You guys need more practice with the die grinder!
Isn't it pretty hard to cut the housings in a straight line?
-Ted
