Sponsored by: CARiD
13B RE Engine Swap
Old Mar 22, 2007 | 08:50 PM
4130E's Avatar
Newbie
13B RE Engine Swap
Hello
I am swaping a 13B RE TT 2 Rotar (cosmo) (1995) engine into a sandrail and need some help with the locating a wiring diagram for the engine and ecu. I am having trouble locating the coil power and trigger wires coming from the ecu (N390 18 8816). Any help would be greatly apperciated as this engine is new to me. Does this engine use a airflow sensor? Thanks?
Old Mar 22, 2007 | 09:01 PM
dubulup's Avatar
development
no a MAP sensor (manifold absolute pressure)
you might be able to use this as a ref.
look for the same color and you'll know that is the 12V source for the coils
the GND for the ECU needs to go thru an ignitor.
I also recommend converting to a single turbo...for simplicity.
cdn
14
Sep 10, 2015 06:23 AM
Machupicchu
Aug 17, 2015 08:27 PM
ncds_fc
Aug 15, 2015 10:06 AM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
