please help with cd deck install, mostly figured out.thnx.
Old Mar 19, 2007 | 08:24 PM
rolandofeld's Avatar
my brainworms hurt...
when i pulled the stock stereo from my gxl and saw all the clips i got a headache. the FAQ acted as an extra strength tylenol for me but...(forgive my electrical ignorance)...
my understanding is that all that is really needed for decent function is power from battery, acc. from ignition, ground, then hook up some speakers. power antenna is not a concern for me, neither is a remote function.
my plan is = butt connect the wires from stock configuration as laid out by the FAQ, to the wiring harness for my pioneer deh-16.
my question(s) = the 50x4 output of said cd deck seemingly will be too much for the 15 watt max for both front and rear speakers. do i just need to find better speakers.
how will the factory amp play a role in this installation, if at all.
if i am able to use the stock speakers how will the individual speaker amps play a role.
any precautions or advice or otherwise is greatly appreciated.
p.s. i am soooooo sick of the radio.
Old Mar 19, 2007 | 08:55 PM
Turbo II's Avatar
It's only Rock and Roll
Remove the stock power amps and speakers, get new speakers and wire it up and enjoy. If you're going to the trouble of putting in a nice deck get some speakers, it's worth it.
Old Mar 19, 2007 | 09:17 PM
jonesfromindia's Avatar
Goofyrotor
get rid of the power amp, hook it up to your deck. they wont blow. i did it, you will be fine. but if you can afford it. get new speakers. CDT, if you cant afford expensive ones get alpine.
Old Mar 19, 2007 | 10:45 PM
scrip7's Avatar
Rotary Gearhead
I am almost finished with my stereo install, I removed the stock amps and installed 6 1/2" MB Quart woofers in the doors, GM/ Delco dome tweeters in the dash, and cut out the rear strut tower speaker plates for 6 1/2" coaxials (originally 4" speakers there) also a JVC double-din head unit ( iPod-ready and sat ready) with my iPod in the console. I also installed a Kenwood amp in one of my rear storage bins. So far it sounds excellent. A lot of newer head units sound good though without an amp, just invest in some new speakers.
Old Mar 20, 2007 | 12:35 PM
helghast7's Avatar
F yo couch!
i have mounting issues on my head unit...how did you guys mount yours because mine is sitting on its own wires and a pair of chemicaly couated heat resistant gloves because theres nothing under it... i need brackets or something what did you guys do?
Old Mar 20, 2007 | 01:31 PM
Osirus9's Avatar
Jackstand Drifter
fyi, the power antenna acts as a ground, and should just plug right in, so I would hook it up if I were you. also the last time I installed an aftermarket head unit in a car with a stock amp it made this loud whining noise over the music, and I couldn't get rid of it until I removed the amp. other than that you seem to be on the right track!
Old Mar 20, 2007 | 10:12 PM
scrip7's Avatar
Rotary Gearhead
I bought an install kit (brand was Metra, but other brands make them). I bought it at Pep Boys (where I work). It came with all the brackets, screws and trim pieces and it looks almost like factory. If you want to hook up your power antenna (if it's electric) you will need to use a relay to send a ground signal to the antenna. Most head units don't send a ground signal, they send a +12v signal which won't work without the relay. As for grounds, do NOT use the antenna plug as your radio ground. It is not a sufficient ground and will usually cause whine noises and static noise. Also do not use the factory radio's ground wire for the same reason. Use the dash bracket bolt at the front of the console for grounding. If you install an amp, ground it somewhere close to the amp using a bolt on the car's body that isn't painted.
Old Mar 20, 2007 | 11:44 PM
helghast7's Avatar
F yo couch!
thanks ill do that...oh and the head unit is already installed (well the wires are) its just not mountedbut now that you mention it i have no idea if my antenna even works mine is broken so i dont no if its hooked up i guess ill check that to... but thanks
Old Mar 21, 2007 | 07:45 AM
scrip7's Avatar
Rotary Gearhead
If you have your antenna hooked up correctly and you hear it's motor running but the mast doesn't go up or down, you can just replace the mast. It's not expensive and you can order one from Mazdatrix.
Old Mar 22, 2007 | 04:20 PM
jgrts20's Avatar
Who are you?
I just found the power, accelarate for ingnition, and ground wire. I rewired all the speakers, which made it easier for the install.
sherff
Feb 24, 2019 12:09 PM
diabolical1
30
Jan 30, 2016 05:50 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
