wastegate lines
Old Mar 19, 2007 | 06:17 PM
13bturbofc's Avatar
mmm doritos
Question wastegate lines
ok guy's this is kinda a newbie question so bare with me..and ive searched and have heard mixed responses.. im running a HKS T04R the greddy frontmount IC kit and the greddy 47MM wastegate on my s4 TII..i cant figure out where the two lines go to on the wastegate..do i drill two holes in the IC pipe and weld two nipples on it or does just one line go to the IC pipe?
Old Mar 19, 2007 | 06:29 PM
13bturbofc's Avatar
mmm doritos
i forgot to add that im going to be running a turboxs manual boost controller
Old Mar 20, 2007 | 02:23 PM
13bturbofc's Avatar
mmm doritos
so no one knows where to run the lines?...come on guy's
Old Mar 20, 2007 | 03:00 PM
Heisenberg's Avatar
Civilization is crumblin
https://www.rx7club.com/single-turbo-rx-7s-23/single-turbo-diagram-discussion-631247/
Old Mar 20, 2007 | 03:30 PM
ikari899's Avatar
engineer wanabe
depends how you want to run the gate. but easiest way is just take one line from inbetween the TB and turbo run it to the boost controller then run a line from there to the bottom of the gate.
Old Mar 21, 2007 | 03:10 PM
13bturbofc's Avatar
mmm doritos
since my compressor housing dosent have a nipple on it for the wastegate line do i have to weld one on the IC pipe or can i just drill and tap a hole in the IC pipe? will that seal?
Old Mar 25, 2007 | 01:42 AM
13bturbofc's Avatar
mmm doritos
bump
Old Mar 25, 2007 | 09:47 AM
Wankel7's Avatar
Haven't we ALL heard this
I would drill and at least try to tap the first pipe that comes out of the turbo. Then you can seal it up with some JB weld. Yeah, I know...blah blah jb weld. It will look just fine. Or you can go pro and weld a bung into the pipe. Then thread it and put in the brass nipple. That would prob look cleaner/better/more professional. But not sure what level you are workn at
James
Old Mar 25, 2007 | 10:17 AM
turbodrx7's Avatar
PURIST
Im running a Profec B spec II and for mine, i have the one side going off the controller, into a T, one end of the T goes to the compressor housing, the other to the Side of the wastegate. THen my other line on the BC goes to the top of the wastegate.
Ian_D
Oct 14, 2015 12:31 PM
Nosferatu
Sep 5, 2015 02:13 PM
rotor_veux
Sep 3, 2015 07:10 PM
