S4 T2 Loss of power, ideas?
Old Mar 19, 2007 | 05:58 PM
Project88Turbo's Avatar
Stock boost FTW!
2 nights ago on the way home from work, my T2 started loosing power while cruising at a steady speed. I had to use 4th gear to keep it moving faster than 40mph, and managed to make it home. When I got back to the house, it sounded like it was running on one rotor
So, I did a ghetto compression check and the rear rotor sounded weaker than the front. The plugs looked horribly covered in carbon, more than likely from all the low speed driving back and forth to work. So I tried a new set of plugs, but there was no change. Getting good spark all the way around.
I got my compression tester out and I got 100psi on the front and 15psi on the rear. I looked in the leading plug holes and none of the apex seals are cracked or missing, no dents/gouges in the rotors, just a lot of carbon buildup on them.
To sum it up: Even pulses from the rear rotor, low compression, no broken parts.
Is it possible that carbon build up has stuck a seal causing the compression to be low?
Vince
Old Mar 19, 2007 | 06:35 PM
gear_grinder's Avatar
Don't hate my V8
if its got ALOT, and again i say ALOT, of carbon it could be a stuck seal. Use the oil in the lower spark plug holes trick and see if that helps. other than that i would say a colaped seal spring. which would mean you might need a rebuild, which would suck. best of luck to ya.
Old Mar 20, 2007 | 10:42 PM
Stock boost FTW!
Update: Tried the ATF trick, but there is still no compression. I took it down the road and back and it blew off the oil fill tube PCV hose!
So, I'm thinking since it is pressurizing the "crankcase" then it must of broken 1 or more side seals.
Any thoughts?
Vince
LunchboxCritter
15
Jan 3, 2016 04:11 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
sYnth.
Aug 17, 2015 07:28 PM
andyvideopro
Aug 11, 2015 09:16 PM
