??Pluming 46mm Tial Wastegate to Profec B??
Old Mar 15, 2007 | 09:49 PM
estevan62274's Avatar
#garageguybuild
Veteran: Air Force
Can anyone help me hook up my Greddy Profec B spec II to my Tial 46mm. Do i use both nipples on the wastegate? becausce the the greddy manual shows hooking up just one nipple to the wastgate! thanks for any help! Steve
Old Mar 16, 2007 | 07:29 AM
#garageguybuild
Veteran: Air Force
Antone have a diagram??
Old Mar 16, 2007 | 09:59 AM
13btnos's Avatar
http://www.tialsport.com/documents/w..._wginstall.pdf
Tells you where to put the line in for the boost controller. They call it the manual air regulator "manual boost controller" or electronic air control valve "electronic boost controller".
Old Mar 16, 2007 | 10:17 AM
#garageguybuild
Veteran: Air Force
SWEET!!! thanks for the help!!!!!
Old Mar 16, 2007 | 10:42 AM
J-Rat's Avatar
Alcohol Fueled!
You have to use both nipples. Doing it off of memory, you should be on the COM and NC ports. The NC port is where the boost control goes (top of the wastegate). The lower nipple gets a reference signal from the car (Normal boost). You can tee this line off the vac line you put into the COM port.
Old Mar 16, 2007 | 01:22 PM
Lynn Bordes's Avatar
Mark White admirer
Good Diagram
https://www.rx7club.com/forum/showpo...11&postcount=2
Barry
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
eplusz
15
Oct 7, 2015 04:04 PM
