loud water rushing noise from dashboard?
Old Mar 19, 2002 | 10:54 AM
lewisjp2's Avatar
after waterpump and houseing gasket replaced. i hear a water rushing noise come from dash. wth is this being caused buy. please help? ideas anyone has this happened to you?
Old Mar 19, 2002 | 10:59 AM
Rotary Master
Don't want to alarm you, but my friend had that same noise and then his motor died in his R1 and after the motor was replaced it was never heard from again.
Old Mar 19, 2002 | 11:00 AM
Rotary Master
Also no one he took it too could tell him why he heard water rushing in the dash.
Old Mar 19, 2002 | 11:50 AM
lewisjp2's Avatar
thank you i heard the samething on someones web site this motor has about 30k on rebuild from pettit thought they said it would be good for 70-100k?
Old Mar 19, 2002 | 11:55 AM
Toadman's Avatar
Nomad Mod
Is the coolant topped-off fully? I'd do a cooling system pressure check. If good, replace your radiator and AST caps also. That noise is from the coolant circulating through the heater core.
Old Mar 19, 2002 | 01:57 PM
Flybye's Avatar
It's never fast enough...
You have air trapped in your heater core. It sounds funny, doesnt it?
Just make sure the coolant system is topped off and bleed.
Old Mar 20, 2002 | 04:26 AM
hawaii rx-7's Avatar
don't stress, it's just air bubbles in the coolant.. happens every time i flush the coolant. just wait for it to cool down, then top it off. do it a couple more times and bye bye sound...
shame on you johnsrx-7 for trying to scare lewis.
Old Mar 20, 2002 | 11:52 PM
badass7's Avatar
Pimpin Rotors...and Hoes
Definitely means your coolant is not topped off. It actually comes from underneath the dash on the passenger side.
Old Mar 20, 2002 | 11:54 PM
i had the same symptom, turns out one of my coolant hose clamp was loosened.
Old Mar 21, 2002 | 06:26 AM
Rotary Master
Hey, I was just telling him what happen to a friend of mine's R1, the engine was drinking coolant faster than he could fill it up.
Old Mar 21, 2002 | 06:59 AM
Brede's Avatar
I had the same sounds! Turned out to be a coolant leak, the dreaded o-ring failure. Exhaust gasses forced their way into the coolant. Rebuilding now..
Old Mar 22, 2002 | 08:06 AM
lewisjp2's Avatar
water noise
thanks all who replied i topped it off noise seems to be quieter it is at the dealer now having check engine light checked hope nothing major
Shainiac
Jul 17, 2019 02:20 PM
