Sponsored by: CARiD
Bad clutch problem
Old Mar 3, 2007 | 12:40 AM
brian_g's Avatar
Bad clutch problem
My 1987 RX7 non-turbo recently gave me a bad clutch problem. When i go into 1st gear to get the car going, or go into reverse, the clutch pedal stays pressed down, and disengages. I have to physically put my toes under the pedal and lift it back up. While it's stuck down there, the car is also stuck in gear. I have replaced the master and slave cylinders, but the problem still persists. Anyone know what's wrong?
Old Mar 3, 2007 | 05:09 PM
Rogue_Wulff's Avatar
Too old to act my age
Either you have a defective clutch master or slave, or there is still air trapped in the system.
Old Mar 5, 2007 | 12:58 AM
brian_g's Avatar
what exactly do you mean by "air trapped in the system"?
Old Mar 5, 2007 | 05:21 PM
trochoid's Avatar
Old Fart Young at Heart
Clutch system is bleed just like the brakes, but without the pumping. If either the master or slave goes out, I prefer replaceing both and the hose, they're 20 years old, it's time.
Skeese
Rotary Car Performance
Oct 28, 2020 11:01 AM
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
Inspector71
Aug 26, 2015 12:06 PM
