DamonB's sub-enclosure, what subs did everyone pick?
Old Mar 18, 2002 | 02:29 AM
daiSho's Avatar
hey all... ok, i've got one of damonB's enclosures sitting here unassembled so far, and need to go ahead and pick out a sub for it... any that got this enclosure (i know your all out there!) please share you choice of subs in this box, and what worked out best? thx all..
Old Mar 18, 2002 | 02:59 AM
thatoneguy's Avatar
I have a RFP3210(10" Fosgate"). I haven't put together the box yet, but I know It's a little big for the box, so I'm gonna put a one inch extra layer of wood around the hole. The reason I got it is cause it was $54 new. =)
Old Mar 18, 2002 | 02:00 PM
HedgeHog's Avatar
Rotary Poseur
I'll be putting the Audiomobile EVO 2210 S4 in.
Unless I get cold feet, in which case, I'll be putting the Image Dynamics IDQ10 V.2 D2 in.
Old Mar 19, 2002 | 12:44 AM
alaskan7's Avatar
I'm with you, I'm going to get the audiomobile evo too, I like all the good reviews and the looks of the sub, I've got my 10+ year old JL Audio sub in there now. If you get it first, let me know what you think, and I'll do likewise.
Old Mar 19, 2002 | 08:01 AM
DamonB's Avatar
My JL is also about 10 years old. Let me know what you think if you switch, Alaskan7.
Old Mar 20, 2002 | 02:05 PM
lenny's Avatar
i put a 10w0 in mine, and it works fine. It wont win any shows, but it works for me.
here's some pics of my setup
https://www.rx7club.com/forum/showth...threadid=61375
Old Apr 8, 2002 | 12:12 AM
HedgeHog's Avatar
Rotary Poseur
Ok...assembled the sub box today. (man, it goes quick with a brad nailer + a circle cutter adapter for a router). The Audiomobile EVO 2210 needs a 9.25" opening to fit. Not to mention the basket frame is 1.5" deep at that opening. So i routered the top and bottom pieces with the circle cutter adapter to that depth. The sub drops right in. However, the overall diameter for the sub is around 10.25" so it sticks past the height of the box.
I'll report how it fits in the car and the sound quality when i get my cables and finish off the install.
Thx, Damon....nice work on the box!
Old Apr 8, 2002 | 02:20 PM
rjuge's Avatar
this week i'm driving...
will a jl 10w7 fit in it????
that would be BAD ***
Old Apr 8, 2002 | 02:39 PM
HedgeHog's Avatar
Rotary Poseur
Nope...the way the W7 mounts require a bigger surface to clear the ring. Also, the W7 needs a bigger box to operated efficiently. Not to mention that u need a huge amp to run that sucker.
Old Apr 8, 2002 | 05:11 PM
Montego's Avatar
Don't worry be happy...
Top Answer: 1
I haven't picket a woofer yet. I was gonna go JL but I'll see what the concensus is first.
Old Apr 8, 2002 | 05:26 PM
DELTA_Rotary's Avatar
Bourbon King
Anybody tried the Square Solo Barics from Kicker?
Old Apr 8, 2002 | 06:04 PM
Larse's Avatar
I'm going with either a Kicker L7 or JL W7 myself...
Old Apr 9, 2002 | 05:33 PM
newRX7fan's Avatar
What happens if I use a sub with a minimum enclosure size that it slightly larger than the box? These enclosures are 0.75cuft and the sub I'm looking at recommends 0.8 or more. Does this make it not as clear or just limit low-end frequency response?
Old Apr 10, 2002 | 12:45 AM
spyfish007's Avatar
Yellow Dragon is no more
A W7 also needs SERIOUS bracing and/or thicker wood. JL calls for 1" MDF or double stacked 5/8" MDF for the W7s.
Old Apr 10, 2002 | 06:44 AM
BOOSTD 7's Avatar
Persona non grata
It will work fine. On the bad side, having a smaller box will make the response curve peaky, probably around 40-60 hz. And it won't go quite as low. On the good side, putting it in a smaller sealed box will increase the effective power handling and the max SPL.
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
Nosferatu
Sep 5, 2015 02:13 PM
