New Inline 4-Barrel
Old Feb 28, 2007 | 10:36 PM
13BT_RX3's Avatar
The General RE
New Inline 4-Barrel
http://www.popularhotrodding.com/tec...l_inline_carb/
Who's going to be the first to try one of these on a rotary?
Old Mar 7, 2007 | 03:20 PM
crispeed's Avatar
'Tuna'
Very nice.
I hope it totally eliminate the problem with the fuel bowl being turned sideways causing problems.
Leave it up to Barry Grant to re-invent the 4bbl carb.
Looks promissing.
Old Mar 7, 2007 | 04:34 PM
Doc Holiday's Avatar
Needs more cow bell
Looks too long to be used on a rotary. Unless they offer a 2bbl version.
Old Mar 7, 2007 | 04:51 PM
crispeed's Avatar
'Tuna'
I've seen dual Weber DCOE's on a rotary so it should fit.
Old Mar 7, 2007 | 05:05 PM
RacerXtreme7's Avatar
NASA geek
it should fit, but I don't see any type of advantage on of a inline arrangement on a rotary over a standard 4 barrell, all other things being equal of corse.
Old Mar 7, 2007 | 05:22 PM
crispeed's Avatar
'Tuna'
Better fuel bowl design just to name one.
Should do a much better job controlling fuel level especially when high G-forces are involved. Only major down fall to the traditional 4bbl design would be the lack of stage secondaries on a rotary applications.
Old Mar 7, 2007 | 06:00 PM
rotaryengineering's Avatar
Talking Inline 4-Barrel
I have a Intake system I just completed for my P-Port motor that looks very similar to that setup. The system consists of 2 Geers Engineering 62mm Carbs joined together to make one huge inline 4 barrel carb. Complete custom setup for my Drag car. Hope to have it running in a couple of weeks.
Old Mar 7, 2007 | 06:06 PM
crispeed's Avatar
'Tuna'
Twin 62mm G's
Should be interesting.
Old Mar 8, 2007 | 09:05 AM
13BT_RX3's Avatar
The General RE
+ 1 on the cornering issue.
An inline design would make it easier to have equal length intake runners. The problem with this BG carb is that the primaries are the 1st and 3rd barrels not the two inner or two outers. The intake manifold might be a little tricky to make.
Old Mar 8, 2007 | 11:41 AM
Peacedog94's Avatar
Fellas,
Not meaning to thread hijack. Quick question here about possible manifold design. I understand that the manifold will be a bit convoluted due to the the 1st and 3rd "barrel" of the carb being the primary ones, but don't you want a fairly long intake runner on most rotaries to allow the air and fuel to mix properly anyway? I always thought that if the intake runners were too short it caused problems with the intake charge?
Curios,
Peacedog
Old Mar 10, 2007 | 10:40 PM
peejay's Avatar
Old [Sch|F]ool
The air and fuel are mixed at the venturi. Everything after that serves to un-mix.
That said, I am reminded of the Autolite carbs that Ford made for the Boss 302, back in 1969... manifolds available were single carb, and independent runner with two carbs. They had a jet arrangement similar to a Weber where you didn't have to disassemble the thing to change jets.
Everything old is new again!
Old Mar 10, 2007 | 10:47 PM
crispeed's Avatar
'Tuna'
That's where It seems the design came from.
Old Mar 11, 2007 | 12:08 AM
Kenku's Avatar
spoon!
Kinda cool little piece of kit. Not sure how useful it'd be for rotaries (that seems like a lot of potential flow) but what the heck. And no reason you can't fiddle around with the linkages that work the secondaries to get them to open differently.
Rotospectre
Mar 28, 2018 03:33 PM
scissorhands
Oct 8, 2015 01:17 PM
R|©haźd
Sep 24, 2015 11:39 AM
