nos on these cars
Old Mar 17, 2002 | 10:53 PM
boostedyellow7's Avatar
nos on these cars
my bud wants to no if he should put a 50 shot on his car. he has a pms and all the goodies. but wants it for when he's at lower boost to help out on the street when he does not hav3e race gas in the car. thanks any help whould be great.
Old Mar 18, 2002 | 05:37 AM
Rotary Master
Your friend needs to talk to Steve Kan (Pluto) or give Rotary Performance a call, they both run 50 shot on the drag strip, but from what I have read, 50 shot is the biggest you want to go on an Rx-7, and you definitly have to compensate for it in the computer.
Old Mar 18, 2002 | 08:41 AM
thanks i will have him call rp today.
Old Mar 18, 2002 | 10:18 AM
NickSimcheck's Avatar
Any more then 50 shot is a no-no with the 13B
Old Mar 18, 2002 | 02:02 PM
Mikey's Avatar
here read this
http://www.rx7turboturbo.com/robrobi...us_install.htm
Old Mar 18, 2002 | 03:50 PM
RX794's Avatar
NYC's Loudest FD
If you guys think that a 50 shot of NOS is all you can put on a turbo rotary, you guys need to wake up. Alot of this once again comes to tuning, and how much boost you wanna run in accordance to the size of the backhousing on the turbo. The reason for this is because once you start to use NOS on a turbo rotary it spins exhaust side of the turbo at such a higher rate, that the backhousing of the turbo needs to be big so that it can keep up with the exhaust pulses, if it's not big enough, it will it will cause the turbo to overspin beyond it's efficiency and just make the intake temp. skyrocket, and therefore causing no HP gains, and/or detonation due to the intake temp being so high. Plus you also have to retard timing to a certain extent when using NOS and how much timing retard depends on how much NOS you're using(I'm not even gonna get into that). I see some guys using 100 shot or more of NOS at the track with no problems because they have the tuning correct, and that means EVERYTHING when it comes to reliability, and making HP w/o blowing up. Just my 2 cents.
Old Mar 18, 2002 | 03:59 PM
the_glass_man's Avatar
Will u do me a kindness?
Originally posted by RX794
If you guys think that a 50 shot is all you can put on a rotary, you guys need to wake up.
Yeah I run a 500 shot on mine with no problems, haven't you ever seen that movie with the big bald dude?
Old Mar 18, 2002 | 04:13 PM
jeremy's Avatar
male stripper
its spelled naws. man, you are just so unhip, yo.
Old Mar 18, 2002 | 04:14 PM
RX794's Avatar
NYC's Loudest FD
Read my post above, I edited it to include more info on the subject.
astrum
24
Nov 15, 2017 08:44 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
