boost problems
boost problems
I got some problems with my boost on second turbo, it goes up to 10 psi at 5000 rpm but drops at higher revs, at 7000 rpm I only have 6 psi.
It is destroing all the fun with the new exhaust cause the car is now slower than last G-tech test with oem exhaust......
Can the catback exhaust cause the lack of boost?
There are quite a few long-termers on the forum that have used the G-tech and found it very accurate for 0-60 and ET. (It will read high on trap speed because it measures the instantaneous velocity at the 1/4 mile, not the average of last 60 feet like the track.)
Gzon: do you still have the stock pre-cat and main cat? They could be clogged. Also, check intercooler piping/y-pipe for leaks.
I got the pre and main cat on, if I make a downpipe, will I need an ecu? or will it work with just a Boost-control to get boost to normal?
Originally posted by gzon
I remember now that my "to hot cat" lamp came on friday after a spin with the new exhaust, is that a sign of a burned cat?
Trending Topics
Originally posted by GoodfellaFD3S
Looks like it's time for a downpipe and/or high flow cat. Be careful driving the car...you don't want to be looking at replacing your motor in the near future!
is it dangerus to use the car? what can happen?
rgordon1979
40
Mar 15, 2022 12:04 PM
Adaptronic Cranking fuel table messed up?
sherff
Sep 12, 2015 12:22 PM
AXA
Sep 5, 2015 10:06 AM
tiger18
Sep 3, 2015 08:27 PM
