Turbo hits my LIM
Old Feb 22, 2007 | 10:49 AM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
Turbo hits my LIM
Well i put my turbo on just for a dry mock up and it hits my lower intake manifold , if only i could get me a spacer to put in between the turbo and exhaust manifold it would work.
does anyone see a problem in doing this, i have a gt40 and its divided...or if someone knows a shop who sells flanges
Old Feb 22, 2007 | 10:54 AM
88rxn/a's Avatar
tom port.. AKA streetport
arent you running the FD SS type manifold?
dont they need a spacer between it and the motor for the turbo to clear? or cut and re-weld the manifold?
not really sure? just wondering becuase i have the same manifold i think?>
Old Feb 22, 2007 | 11:40 AM
RETed's Avatar
+1
FD turbo exhaust manifold will position the turbo closer to the engine.
Trying to stuff it on an FC3S 13BT will cause the turbo to hit the LIM.
You can try running an on-center turbine housing, if it's feasible, to get added clearance.
-Ted
Old Feb 22, 2007 | 12:11 PM
hondahater's Avatar
spending too much money..
I got one for sale. .96 70bux let me know.
Old Feb 22, 2007 | 12:32 PM
turbodrx7's Avatar
PURIST
Racing beat makes a spacer, we used one on a friends FC with a t66 we just completed. It spaced it out just enough to clear the manifold. I will have to ask my brother where he ordered it from though.
-Austin
Old Feb 22, 2007 | 02:01 PM
MODERATOR
-Austin
please do so man i need this real soon
Old Feb 22, 2007 | 02:25 PM
dubulup's Avatar
development
^racing beat sells them. search google for the website
Old Feb 22, 2007 | 03:06 PM
fastrotaries's Avatar
W. TX chirpin Monkey
Racing Beat products can be found at... www.Racingbeat.com Just thought I'd point out the obvious.
Old Feb 22, 2007 | 05:06 PM
No_Rotor_RX7's Avatar
yep, i've done this as well on a few different cars. on my current TII with a 70mm turbo Qtrim i have insane amounts of clearance by using a spacer between the manifold and turbo i made... instead of block to manifold. ether way works just use a gasket on both sides
Old Feb 22, 2007 | 07:57 PM
kabooski's Avatar
Laying Down Rotary Law
theracingstore.com
in orlando has them
call them there sometimes open till 7pm
Old Feb 22, 2007 | 11:11 PM
88rxn/a's Avatar
thing is:
which way is better?
between the block and manifold spacer OR
between turbo and manifold?
yeah i know, shouldnt do either......
Old Feb 22, 2007 | 11:48 PM
Turblown's Avatar
Turn up the boost
Doing the spacer is a better route. If you've ever experienced an on-center turbine housing you will agree...
And yet you still see people putting a thousand bends into exhaust manifolds to get equal length LOL....
Rotary Performance Parts
Old Feb 23, 2007 | 02:09 AM
FrankV702's Avatar
Hey el nene.. I have a flange.. I think I may even have two. I used it on my old setup to put the FD manifold on the FC.. PM me
Old Feb 23, 2007 | 09:07 AM
dubulup's Avatar
development
The spacer will buy you the clearance to mount the turbo...but now your turbine housing is XXmm away from your LIM.
My question is...how close is too close?
1Revvin7 - love the FD manifold in your sig!!
Old Feb 23, 2007 | 09:41 AM
KNONFS's Avatar
B O R I C U A
I had the same issue, ended up building a spacer; however I don't know how it will affect perfomance, as the car is not ready (yet )
Spacer has a V shape, like this / \ on my case there is 3/4 gap on the narrow section, and 1 1/2 on the wide section. I might be able to get you some pics during the weekend.
Old Feb 23, 2007 | 09:43 AM
KNONFS's Avatar
B O R I C U A
Yes, I have about 3/4 of clearance between the turbo and the manifold. I will use a turbo blanket, and will invent some sort of barrier between the hot side\DP and intake manifold.
Old Feb 23, 2007 | 10:06 AM
MODERATOR
awsome i was looking at the flange racing beat sells and i am iffy about a couple of things it seems like i might have to remove the stud bolts and put longer ones ...do i
but i will give it a try with the heat wrap on the hotside i should be ok with the heat transfer to the lim i am just afraid of it getting too hot and my fuel igniting in the lim before it even gets to my chambers
Old Feb 23, 2007 | 10:20 AM
KNONFS's Avatar
B O R I C U A
I bought a threaded flange, an a non threaded one; the manifold has a threaded flange, so basically the non threaded flange sits on top of the manifold's flange.
Don't know about the fuel igniting on the LIM (yet)
Old Feb 23, 2007 | 10:38 AM
MODERATOR
PICS theres a couple of guys that pmed me about this mod because of the same manifolds so if anybody has a pic of their set up let see it i have to get mines so when i get it i will post a pic too
Old Feb 23, 2007 | 10:44 AM
funklove's Avatar
In rotor we trust!
I used this
this
and this
HKS manifold fits fine now on 13B-RE
Old Feb 23, 2007 | 10:45 AM
MODERATOR
damn computers from work i cant see the pics i will see them when i get home
Old Feb 23, 2007 | 12:38 PM
88rxn/a's Avatar
id like to see som epics also,
EL Nene 7,
when you figure this out.
would you post some pics on how you did this?
i am a few months form doing this project or i would.
thanks!
Old Feb 23, 2007 | 02:01 PM
RacerXtreme7's Avatar
NASA geek
LOL!!
Originally Posted by funklove
I used this
this
and this
Old Feb 23, 2007 | 02:20 PM
vipers's Avatar
IIMMM BBAAACCKKK!!
i have the fd mani as well..... all guitarjunkie28 did was cut off the turbo flange, cut a minor pie shaped section of the tubing to move the housing away from the manifold..and rewelded it back on (and also went over some of the other welds to further strengthen it).... i think having a shop do that will be far cheaper than buying the spacer..... and then it will fit w/out any spacers, which in my book, is a better way to go
Old Feb 23, 2007 | 05:35 PM
RX-Heven's Avatar
I'll blow it up real good
Should have just bought my old setup
