Ford 8.8 install
Old Feb 11, 2007 | 04:29 PM
SneakinDeacon's Avatar
Ford 8.8 install
I've tried to search through the forum but all i really see is people who have done it and say it is easy. i havent seen anything in depth about how it is installed. does it use the same mounting points minus the upper control arm "ears". does the watts linkage stay in place or do you have to convert to a panhard? any direction would be greatly appreciated.
Old Feb 11, 2007 | 06:00 PM
kenn_chan's Avatar
Savanna Rx-7
grannys speed shop make a bolt in unit that fits exactly the same as stock with your choice of axels and or brake units. just google them.
kenn
Old Feb 11, 2007 | 07:26 PM
i dont want to spend 2k on the setup, thats the thing. if thats my only alternative (which i really doubt it is) then ill just put an 8.8 into my FC...but i was really wanting to toss my engine from my FC into an FB for the weight savings and ability to have a solid rear with alot of gearing selection. i break T2 axles/housings like they arent even there, its getting old.
Old Feb 11, 2007 | 07:46 PM
Rx-7Doctor's Avatar
What motor and HP are you running in your 1st gen?
Old Feb 11, 2007 | 08:13 PM
i have a 2nd gen currently. running a 406sbc and 350 on the bottle. as far as power, 500 on motor, right around 800 on bottle.
i have someone who wants my shell though, so figured i could flip it and get myself a gutted FB and do an 8.8 in it cheaper/easier than i could in the FC.
Old Feb 11, 2007 | 08:36 PM
84RX_Se7en's Avatar
Rockin' the suburbs!
Wow.
Pics or it didn't happen!
Old Feb 12, 2007 | 12:37 AM
lol, its just a good ole gitterdun sbc in an rx7. it aint pretty but function before form right? thats with the torker manifold. got a different one setup for direct port. pic is a bit outdated
but anywho, i vaguely remember granny's offering a solid rear setup for the 1st gens for like 800 bucks a long while ago...but they've changed their site around with the addition of the FC solid axle and stuff, and claim it as a 1st gen modification aswell, so im not sure if they still offer the 800 dollar thing or not. ill ring them tomorrow and keep the thread updated with whatever i find out incase anyone tries searching for the same thing as me lol.
Old Feb 12, 2007 | 11:09 PM
well, granny's setup is 1750 for a generic setup basically. no one fabbed up their own?
Old Feb 12, 2007 | 11:32 PM
81gsl12a's Avatar
blown up motors
just getthe 8.8 and hack the mounts off the stock rear end weld them to the 8.8 i should take you less then 5 hrs to do this... its really not hard.
Old Feb 13, 2007 | 01:10 AM
sounds pretty straight forward then. thanks for the reply.
Old Feb 13, 2007 | 06:35 PM
90turbo1's Avatar
contact grannys, they probably will sell you the mounts that they use, and then just weld them up to your 8.8.
I think there is a size difference in width, the grannys is shortened and all that stuff.
I am pondering the same with my 1st gen the donor car I have is a 8.8 so I might as well use it.
Old Feb 13, 2007 | 08:10 PM
...who moved this...
i dont see what "other engine conversions" has to do at all with putting a different rear end in an fb.
Old Feb 13, 2007 | 08:11 PM
Old Feb 16, 2007 | 11:52 PM
theantirotor's Avatar
duh man, you mentioned a V8. clearly any suspension tech questions you have would not apply to non v8 rx-7s?!?!
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
t-von
Sep 10, 2015 01:56 PM
tonka_1956
Sep 2, 2015 05:55 PM
