exhaust dilemia!!!
Old Mar 15, 2002 | 02:11 AM
MazdaRx7Power's Avatar
exhaust dilemia!!!
so i straight piped my car with the true duals.. and its way to dam loud. anyone have any ideas or something i can do to quiet it way down. something that can just be put in the exhaust itself instead of paying for someone to weld it again
Old Mar 15, 2002 | 05:06 AM
I wish I was driving!
yeah, add cats, presilencers or mufflers in the downpipe area. Presilencer or muffler will not do much to performance.
Or get ear plugs and a better stereo.
Sean Cathcart
Old Mar 15, 2002 | 08:49 AM
Grimlock's Avatar
a good quality pre-silencer
just like scathcart said, in the middle of the exhaust system. i have one on my TII and she is very quite. its a rb one. i know the turbo also quites the system down but it should help you aswell.
Old Mar 15, 2002 | 09:01 AM
yeah but i meant something i can just stick in there. presilencers have to be welded on. and also theres 2 pipes. dont want to weld anything.
Old Mar 15, 2002 | 09:11 AM
Taranis's Avatar
Then have an exhaust shop fab you two presilencers that you can bolt up. You're still gonna have to cut your exhaust to make 'em fit. There is nothing you can "just stick in there".
- JB
Old Mar 15, 2002 | 01:31 PM
Papasmurf's Avatar
A banana.j/k No, but I have seen some cars that have straight pipes and at the end they have a slide in silencer that just bolts in like the Tanabe or an Apex does.
Old Mar 15, 2002 | 01:37 PM
i just tested something out on mine, i put some steel wool in the exhaust. muffles alot more then before i dont have that harley sound that much anymore.
Old Mar 15, 2002 | 02:33 PM
Mark S's Avatar
You mean you just jammed some wool in the pipe? Not a good idea. It'll flow terrible.
All a presilencer is, is a chamber with a perforated tube the same diameter as the exhaust piping. The stainless wool is on the OUTSIDE of the perforated pipe in the chamber. This doesn't really disturb the flow characteristcs that much and quiets down the exhaust considerably.
When you fabed the true dual, did you use thick walled tubing? This makes a VERY big difference in the sound-levels inside the car. The thin walls of the tubing transmit the sound into the engine cabin.
With thick-walled exhaust tubing, it'll still make your ears bleed outside the car, but I have no trouble driving 10-12 hours with my dual set-up.
If the tubing is thin walled (What most muffler shops use), its going to be more difficult to quiet it down. Not impossible, but much harder.
I don't know of any way to do it without welding in additional pieces, so get cutting.
Old Mar 15, 2002 | 03:46 PM
Ryde _Or_Die's Avatar
First off, do you have mufflers at all? Second if you do, get some presilencers and just have some flanges welded on by an exhaust shop. Then you can cut the same size piping out as the presilencer yourself and bolt it in. Third option-buy an econo car
Old Mar 15, 2002 | 04:54 PM
i put some steel wool in it a couple of hours ago. air still flows pretty good out of the pipes. muffled it alot, compared to what it sounded like before.
Old Mar 15, 2002 | 08:54 PM
well, just to jam in something, try a header insert pipe. They flow like a beauty, and are used in V-8 race cars so that they can meet NHRA race sound specs and yet run open headers.
Summit sells them, part number: CCI-3DI02R
page 190 on the new catalog.
this requires you to have 2" exhaust pipe on both pipes, at the minimum.
I dunno about steel wool. That's more of a temporary thing.
I do think your methods seem pretty slack.. for performance exhaust, you just wanna jam something in there? Weld in some XR1's and do it right.
Sean
Old Mar 15, 2002 | 09:01 PM
ponykiller's Avatar
Just install a turbo! The compressor wheel will silence the exhaust some and you will also love the power gains.
OK, ok. I was just kidding. (it is a good idea, though)
there is nothing you will be able to do without more welding, as everything must be placed in the exhaust gas stream, which means cutting and welding.
Kris
PS-this is my 100th post!! (what is my next goal, 1,000? that is gonna take years)
Ian_D
Sep 6, 2015 10:38 PM
doritoloco
Sep 5, 2015 12:41 PM
FührerTüner
Sep 4, 2015 01:41 PM
