Need Help Fast!! Konis don't fit
Old Mar 14, 2002 | 06:40 PM
CrazyJoe12a's Avatar
OK I am out in the garage tryin to install a set of Koni Orange adjustables in my buddies 1980 GS. Now we have the struts apart and everythigni s good unitl we insert the koni's into the strut housing. the new inserts will not go down far enough to let the new locknut fit onthe housing. Has anyone else encountered thi problem?? If so what did you do. If it would be easier to explain in voice lemme know and I will call (on my phone bill) to get advice!!!
Thank you in advance
Old Mar 14, 2002 | 07:01 PM
crankit's Avatar
Have an 84GS and both of the struts were changed before I bought it and neither one of the housings screws down all the way you know where the strut goes in. My local mechanic says its nothing out of the ordinary as long as you can screw the caps down some.
Old Mar 14, 2002 | 07:02 PM
Max7's Avatar
Admitted Sevenaholic
Only thing I can think off hand is that you have 81-85 struts that your trying to use... are they made for the 79-80 model?
Old Mar 14, 2002 | 08:25 PM
nipplebandit45's Avatar
mine fit perfect last night. but hten I do ave an 84. ight be a different size.
Mike
Old Mar 14, 2002 | 08:27 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
when i put the konis on my 81 i had to cut 2 of the little spacers off the bottom of the strut. BLAM fit like a glove.
Old Mar 14, 2002 | 09:14 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
The Ground Control website says that the Koni racing strut inserts only fit with their "custom struts". I'm not sure if these are what you have, sorry I can't be much help.
Here's the website where I saw this:
http://www.ground-control.com/gcrx7cat.htm
Old Mar 15, 2002 | 12:10 AM
peejay's Avatar
Old [Sch|F]ool
Ok, I forget if the '80 housing is shorter or longer than '81-85... either way, you have the wrong strut cartridge.
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
fidelity101
13
Aug 31, 2015 07:47 PM
