i suck at offsets, so i need quick verification
Old Jan 30, 2007 | 03:31 PM
dbragg's Avatar
Say hello to Mr.Wankel
i got my moser 5 lug axles from respeed ready to go in. all i need to do is put the studs in. i have a set of ARP studs that are much longer than the stock studs. i dont want to use these unless i have to. because i want to be able to use the lug nuts i paid $100 for and i wont be able to with studs as long as they are. so i need to know if my wheels will fit without any rubbing issues. im sure they will, i just need confirmation.
heres the specs:
16x8 with offset of 26. i dont know if its positive or negative, i assume positive? so will this fit on the rear of an SE without issues?
thanks
Old Jan 30, 2007 | 05:04 PM
dbragg's Avatar
i just did a rough measurement. they have right at 6" of backspacing...anyone?
Old Jan 30, 2007 | 08:21 PM
rotor vs. piston's Avatar
Function > Form
Assuming the new axles stick no further out than the stockers and your 26mm backspacing your wheel should stick outside of the stock fender. I run 16x8 on my watanbes with 32mm 225-50-16 rubber and they rub... 14mm less offset would put the rubber right on the outer edge of the fender from my messurement...
BTW I'm using -SE bits... I can't remember if you were to... I know the stock offsets are ~20 mm difference between the -SE and other models.
Old Jan 31, 2007 | 07:30 AM
Siraniko's Avatar
RX for fun
No way. The max you can do is 5.25 and thats close. Thats what my other friend is using in his showcar RX-3.
Im running 4.75 backspace on a 15x10 epsilon in my 75 RX-3 and 15X9 in the 73 RX-3
Old Jan 31, 2007 | 08:07 AM
dbragg's Avatar
^^ damn....i guess ill need to use spacers then.
Old Jan 31, 2007 | 07:00 PM
Function > Form
Okay, WOW completely missed the 6" of backspacing...
Old Jan 31, 2007 | 09:07 PM
dbragg's Avatar
haha yeah, im using SE bits. i guess i need to try to figure up what size spacers i need now.
Old Jan 31, 2007 | 09:24 PM
trochoid's Avatar
Old Fart Young at Heart
Post baack what you think of those axles. I'm going to need a set with the 5 lug FC bolt pattern for my SSRs when I install them.
Old Feb 1, 2007 | 06:27 AM
dbragg's Avatar
well, i can go ahead and tell you they look like theyve been designed better than the stock axles, better transitions. im sure the composition of the metal is a lot stronger as well. these axles should be able to stand up to a good bit. ill let you know how fitment and all is. i have held them next to stock SE axles, and they look like theyll work perfectly.
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
