Momo PitStop EBrake Handle Install on FD
Old Jan 28, 2007 | 09:37 PM
FDNena's Avatar
I
I did this a while ago and another member asked me about fitment. Here is what I did short and simple. Some pics and commentary for you.
First I cut off the stock leather. Then took a dremel and shaved the rubber down all around. You don't want to cut it off cause the handle will have too much play. So shave a bit and test fit it as you go.
Then I took a metal shaving bit for the dremel and ground down this little bottom section to allow the Momo piece to sit lower on the handle since it is longer than the stock piece.
Next I took the actual handle and cutout 1/2in. piece on the bottom. Again to make it sit lower.
It probably took me about 1hr since I wasn't sure of what I should do to get it to fit. I topped it off with a Miata button. The part number is in one of DaleClark's posts. It was like $6. Good luck I get a lot of compliments on the handle.
Old Jan 28, 2007 | 09:45 PM
XxMerlinxX's Avatar
Team Benjos Captain
Pics?
Old Jan 28, 2007 | 09:47 PM
FDNena's Avatar
I
Sorry I have to resize the pics since this section will not do HTML. Here are the thumbnails for now....
https://www.rx7club.com/showthread.p...53#post6574653
Old Jan 28, 2007 | 10:13 PM
FDNena's Avatar
I
Okay, Here are some pics and commentary for you.
It probably took me about 1hr since I wasn'r sure of what I should do to get it to fit. I topped it off with a Miata button. The part number is in one of DaleClark's posts. It was like $6. Good luck I get a lot of compliments on the handle and ****.
Old Jan 28, 2007 | 10:17 PM
RE-Amemiya's Avatar
Not the company
Nice work!
Old Jan 28, 2007 | 11:00 PM
Punished's Avatar
Play in my tree house.
looks awesome, great work.
Old Jan 28, 2007 | 11:19 PM
rx7goomba's Avatar
She's awsome. She posted this after i asked her how she got her momo ebrake handle to fit so good. Thanks for the help and great "how-to" snkydvl
Old Jan 29, 2007 | 12:48 AM
WePlayWii's Avatar
More pics from another angle? Looks great.
Old Jan 29, 2007 | 08:23 AM
FDNena's Avatar
I
Thank you to all....
Here is the only the other pic I snapped. I am changing the boots to new ones now so it is all apart.
Old Jan 29, 2007 | 05:20 PM
rx7goomba's Avatar
Can you measure the diameter of the bottom piece that the boot will connect to. Im having a new ebrake boot made...and need to make sure its not made to tight. Thanks
Old Jan 30, 2007 | 07:56 AM
FDNena's Avatar
I
I just got a new boot and is 1.5 inches at the top. The stock one fit fine so if you give the person your stock boot they can just use it as the template.
Old Jan 30, 2007 | 11:06 AM
rx7goomba's Avatar
Really....its seems like that momos connector at the bottom would be bigger it diameter. Thanks for info.
Old May 12, 2009 | 10:54 PM
RCCAZ 1's Avatar
So, is this the Miata part number or the universal part number? I'm looking into the carbon fiber one, so do you need to order the handle, leather boot and the adapter??
Thanks!
Also, any other pics of the install would be appreciated!
Old May 13, 2009 | 01:54 PM
RCCAZ 1's Avatar
Bump.... anyone?
Old May 14, 2009 | 10:26 PM
RCCAZ 1's Avatar
Bump again... sorry... just trying to get a response. I know that several have installed this upgraded handle.
Old May 15, 2009 | 10:43 AM
frankadelic's Avatar
Frankie V
boot connection to handle...?
This may be a stupid question but as I'm fabricating my own e brake handle I'm a little stumped as how the e brake boot connects to the actual handle (without slipping loose). As I recall on the stock it's tied by a wire however I was going to cut a thread at the end of the handle and have a lockingg nut at the end pinching the boot in between. Just don't know if it will hold. Do you have a pic or explanation for how momo does it?
Old May 15, 2009 | 02:36 PM
MyRedFD's Avatar
Enter Title Here
Redlinegoods.com has a how to on installing the boots on their site. http://www.redlinegoods.com/FDinstall.shtm. If you use a zip tie make sure the square of it is at the front (or bottom, whatever you want to call it) part of the handle, otherwise you will be able to see it sticking out from under the boot.
Old May 17, 2009 | 10:07 PM
FDNena's Avatar
I
Thanks!
I only ordered the handle at first. You can use it with the stock boot. I used a zip tie like the Redline instructions. Never had a problem with it; it fits nice and tight. I got new boots later on made by one of the forum members. Sorry I don't have other pics and I am leaving the country until June so I won't get a chance to post any. I used the Miata Chrome button on mine. Here is the quote from Dale's post (ClubRX is down so you won't be able to see the writeup):
Originally Posted by DaleClark
Hey guys -
First one is a neat discovery. Mazda had an accessory for the later Miatas that's a replacement button for the E-brake - either silver or chrome. I bought the cheap one (silver) to try out, and it fits PERFECTLY - takes 30 seconds to swap out. I do recommend the chrome button, though - a little more, but should look better and hold up longer. Chrome part number is NC35-44-033, and Ray at Malloy (888-533-3400) has 'em for $9.69 each. The silver one is $3 if you really wanna get cheap . Writeup with pics -
http://www.clubrx.org/default.asp?id...ntent=56&mnu=3
The button just unscrews IIRC.
The end of the handle has small holes so if you want you can use a wire to secure the boot instead and thread it in through the leather. I was fine with the zip tie and in two years it never came loose but I also don't drive the car often. It would only take a few more minutes to use a wire and twist the ends tight. I don't think a locking nut will keep the boot tight all the way around.
Snook
14
Oct 1, 2015 10:56 AM
apooch
Sep 4, 2015 10:27 AM
tiger18
Sep 3, 2015 08:27 PM
