my garage paint job on my 84 gsl
Old Jan 28, 2007 | 06:06 PM
hotimport18's Avatar
just finished sanding an buffing single stage dupont nason paint
Attached Thumbnails my garage paint job on my 84 gsl-picture-082.jpg   my garage paint job on my 84 gsl-picture-083.jpg   my garage paint job on my 84 gsl-picture-084.jpg
Old Jan 28, 2007 | 06:20 PM
d0 Luck's Avatar
raysspl.com
how long did it take you to do it? and how much you spend?
looks good... now let's see some closeups.
Old Jan 28, 2007 | 06:23 PM
Yellow '79's Avatar
ERIC
looks good, how did you do the pin striping?
Old Jan 28, 2007 | 06:25 PM
Cascadia's Avatar
Seattleite-moss optional
That looks pretty damn nice! The whole car looks great! Nice job!!
Old Jan 28, 2007 | 07:06 PM
i spent about 350.00 on material.. the paint it self was only 210.00 an so easy to spray. the body was allmost flawless but it was really sun faded so i wet sanded evrey thing with 400 grit then used a gray sealer then painted....as for the pinstripe its a vinyal sold at ur local auto parts. the nason paint made by dupont sprays nice , covers nice, an sands nice with 2500 grit an is so easy to buff
Old Jan 28, 2007 | 09:05 PM
TiViD's Avatar
TiViD
great job, looks awesome. Did you spray any clear over that?
Old Jan 28, 2007 | 09:15 PM
rbf41182gt's Avatar
+1 for garage painting!!!
except my body was FAR from flawless...
great work!
Old Jan 28, 2007 | 09:37 PM
woodonastick's Avatar
my fb is older than me
wow...you say spray, im thinking rattle can? if so..DAAAAMN
real nice job
Old Jan 28, 2007 | 09:48 PM
mazdaverx713b's Avatar
Have RX-7, will restore
excellent job!! how does it look under flourecent lighting? what is the name of the color?
Old Jan 28, 2007 | 10:54 PM
josh...just josh's Avatar
The TII will live again
what type of paint of that? enamel or acrylic? by gray sealer I'm guessing you mean primer-sealer right?
Old Jan 28, 2007 | 11:19 PM
85rotarypower's Avatar
love the braaaap
What kinda spray gun did you use for that? I've got a siphon feed gun here that I was planning on using for the primer on my car, but I'm not sure if it would leave a good enough finish for spraying a base and clear coat on a car.
Old Jan 29, 2007 | 04:27 AM
its a enamel single stage paint an the sealer was a primer/sealer.. i used a top feed spray gun with a 75 gal comp
its a enamel single stage paint an the sealer was a primer/sealer.. i used a top feed spray gun with a 75 gal comp i rented
Old Jan 29, 2007 | 04:50 AM
trochoid's Avatar
Old Fart Young at Heart
Paint job looks very good from the pics. I used a single stage urethane on the widebody and it turned out to be one of the toughest and most durable paint coatings I've used. Since it's such a tough paint, I don't even wax it in hopes it starts to wear down some before I do my final paint job when Phase III of IV of build process comes 'round.
Nice to see someone doing a decent DIY paint job that isn't a rattle can. Keep up the good work.
Old Jan 29, 2007 | 07:51 AM
RE-Amemiya's Avatar
Not the company
Looks good!
Old Jan 29, 2007 | 11:19 AM
Nailbanger's Avatar
Looks damn good! My 7 is close to the same color. Is it a stock color?
Old Jan 29, 2007 | 11:39 AM
its a late 80's mazda color ...i think they used it on the mazda 323
Old Jan 29, 2007 | 11:59 AM
locopr1's Avatar
looks great! I might try to do it... Gives me some inspiration!!!
Old Jan 29, 2007 | 01:17 PM
Tha Driver's Avatar
A siphon gun will work just fine. Paint jobs are all about the prep, especially if you're going to sand & buff. Shooting the paint is the easy part: it's the prep & sanding & buffing that're the hard work.
Nason is decent paint. Cheap but not quite as durable/chip-proof as more expensive shtuff. I would suggest everyone use base-clear, as it's much eaiser to shoot (& fix mistakes such as bugs & trash while shooting) & the clear eliminates fade by cutting down the UV.
~ Paul
aka "Tha Driver"
The United States is the only industrialized nation to *outlaw* hemp production.
Old Jan 29, 2007 | 02:03 PM
3rd and final 7's Avatar
wheres the water goin?
looks creally damn good!
Old Jan 29, 2007 | 03:39 PM
Wink
i picked nason paint because i used it before an it held up extremely well on my truck for the last 6yrs now....an by the way if u choose to u can clear nason!
Old Jan 29, 2007 | 03:40 PM
thanks for all the kind words!
Old Jan 29, 2007 | 05:34 PM
love the braaaap
~ Paul
aka "Tha Driver"
I don't know about that. The siphon gun I have I got on sale for $15! It was regular $40. I don't want to do a base/clear combined as I'm painting the car black. I've been told that a separate base and clear is the only way to get a real nice finish. I'm going to experiment on the spoiler, hood and fender first then if the results are good enough I'll move to the rest of the car.
Old Jan 29, 2007 | 05:57 PM
a lot of restoration guys use single stage paints because they are period correct an the car comes just as nice as basecoat clear coat!
Old Jan 29, 2007 | 06:00 PM
i would stay away from the syphon gun...old technology...yuk...ull get a better spray pattern and covarge with a gravity feed gun.
