SP Engine 12A + 13B combination
Old Jan 23, 2007 | 09:23 AM
luism12lm's Avatar
Question SP Engine 12A + 13B combination
Do you guys think this combination will work? 12A SP front plate + SE 13B SP Housing w/rotor + SE 13B SP middle plate + SE 13B SP Housing w/rotor + 12A SP end plate. If the combination works, do I need the 12A water pump or can I used the SE 13B. What else would I need?
Thank you
Luism12lm
Old Jan 23, 2007 | 10:42 AM
Midwest 7's's Avatar
sellout
i think thats a pretty common thing to do.
yea use the se oil pump, water pumps are the same.
you'll need to use all the se rotating assembly.
the front covers are the same except for the se 4 omp lines instead of 2 so if your not going to premix run the se one.
Old Jan 23, 2007 | 11:38 AM
rxtasy3's Avatar
unless ur going to use the SE injection, there's really no reason to use the SE center plate. of course if it's already ported then use it. just plug the injector holes if going with carb.
Old Jan 23, 2007 | 11:43 AM
vipernicus42's Avatar
Rotoholic Moderookie
Umm... isn't there going to be a problem with the location of the water jacket O-rings, or is that only on 2nd Gen 13b's?
Jon
Old Jan 23, 2007 | 11:53 AM
sellout
Jon
yea thats on 2nd gens.
all 85 and older stuff is interchangable.
Old Jan 23, 2007 | 12:41 PM
luism12lm's Avatar
Can I use the 12A Intake port template to port the SE 13B middle plate?
Thank you
Luism12lm
Old Jan 23, 2007 | 12:46 PM
sellout
Thank you
Luism12lm
you'll have to read up on that.
usually the middle plate doesnt get as large a port.
Old Jan 23, 2007 | 03:40 PM
diabolical1's Avatar
yes, keep the primaries as mild as you can. get the template that the Gen II N/A guys use on their primaries.
Old Jan 23, 2007 | 03:57 PM
Siraniko's Avatar
RX for fun
You want performance? Use the plates with the tallest ports, then port it. Forget about doing mild streetport. Always go for max ports.
Now since you're going to use the SE housings, plug the injection ports. If you use it (oil injection), you will have lots of smoke. With the OMP, the SE has 4 lines. You have to use "Wye" wherein you combine 2 lines into 1, for a total of 2 OMP lines.
Ciclovnz
Oct 18, 2015 03:04 PM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
