whatmight be "Chirping" under my car??
Old Mar 13, 2002 | 08:46 PM
nipplebandit45's Avatar
Question whatmight be "Chirping" under my car??
Ok I just got back from a test drive in my car and I have an odd problem.
when I am decelerating in gear with out touhing th clutch I hear a "chirping" noise from what sounds like the lower right side of my Tranny housing. It actualy sounds like it is coming fro my passenger floor beside the tranny tunnel, but Im sure it isnt.
any one have an idea as to what I should look for?
Mike
Old Mar 13, 2002 | 08:51 PM
Felix Wankel's Avatar
Super Newbie
Does it go away with the clutch in?
Old Mar 13, 2002 | 10:33 PM
4ohfour's Avatar
could be a bird trapped in your engine bay.
cheers'
Old Mar 14, 2002 | 01:14 AM
yes if I press the clutch it goes away.
and I already did the customarry bird check. no birdies there.
Mike
Old Mar 14, 2002 | 01:17 AM
Super Newbie
May be the throwout bearing. Thats all I can think of that chirps.
Old Mar 14, 2002 | 02:06 AM
abeomid's Avatar
ok i had the same problem, you gotta pull out the tranny. it can be one or more of following bearings which are all cheap (beside pulling out the tranny):
1. Pilot Bearing
2. Throw-out bearing
3. Input-shaft bearing for Tranny
mine was all of them and the noise was gone after change.
Old Mar 14, 2002 | 02:29 AM
V8kilr's Avatar
input shaft bearing is a biiitch to get out,took me two hours and 4 beers
thats where i put the cheers sign but its not working
Old Mar 14, 2002 | 02:31 PM
abeomid's Avatar
for the input shaft, you need a bearing puller for sure, good luck getting it out with a screwdriver and hammer.
Monsterbox
Jul 29, 2022 10:48 PM
astrum
24
Nov 15, 2017 08:44 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
