Starving for fuel at high RPM
Old Jan 20, 2007 | 09:33 AM
Theknifemaker's Avatar
The car is an 81 with rebuilt motor (20K on new motor) New nikki carb, everything stock, new plugs and wires, vacuum lines, fuel filter. The car runs great and idles at 750 rpm but when I am in 3rd and punch it at about 5500 to 6000 rpm it seems to lose power like it is starving for fuel. What can I check?
Old Jan 20, 2007 | 09:42 AM
Siraniko's Avatar
RX for fun
Talking
You said the magic word: Fuel
Old Jan 20, 2007 | 10:15 AM
sgieldon's Avatar
Do a Fuel Volumn and Pressure Test as Per Haynes or FSM Manual Specs.
I think it's Fuel Pump issue and the above test at least will give you a direction to start at.
sgieldon
steve
Old Jan 20, 2007 | 01:18 PM
diabolical1's Avatar
what pump are you running and how old is it?
Old Jan 20, 2007 | 01:33 PM
Rx-7Doctor's Avatar
Question
When you stated "New Nikki". Did you mean that it is a brand new carb or it was just rebuilt?
Old Jan 20, 2007 | 01:35 PM
OnlyOnThurs's Avatar
TACOCAT
CHECK THE FLOATS IN THE NIKKI!!! When my friend was rebuilding mine he had set the floats incorrectly the first time and the car felt EXACTLY how yo uare describing....When he went back to correct the setting the car ran amazinG!
Old Jan 20, 2007 | 04:25 PM
I dont know what type of fuel pump, came with the car. The Nikki is brand new, New old stock and foalts are where they should be (matched numbers off of the carb and they are stock for an 81 and definatley new). Could it happen to be the cold weather? How do you check the fuel pump to see if it is up to spec? Thanks for the help.
Old Jan 20, 2007 | 06:39 PM
DAVID GRIMES's Avatar
How About A Cup Of STFU
Cold weather in Shreveport, Louisiana ? Uh.... no.
Queppa
Nov 18, 2024 03:47 AM
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
Rotospectre
Mar 28, 2018 03:33 PM
Microtech
30
Apr 23, 2016 06:37 PM
