just some quick tech questions.
Old Jan 19, 2007 | 03:15 PM
Old Tex's Avatar
number 1.
whats the average vacuum and 12a should pull at idle?
number 2.
what should i gap my spark plugs to on my turbo 12a with my msd and webber.
number 3.
i want to run a fuse for the power wire from the battery to the main power connection in the engine bay. whats zise fuse should i run?
Thanks again
Old Jan 19, 2007 | 04:12 PM
trochoid's Avatar
Old Fart Young at Heart
1. 14-18 Hg, depending on porting, May be a bit higher with good compression. My 1/2 bp with 120psi after the rebuild pulls 8-9 Hg due to the overlap.
2. Can't help there.
3. 60 amp minumum, depending on added accs and alt upgrades.
Old Jan 19, 2007 | 08:18 PM
REVHED's Avatar
Hunting Skylines
What sort of plugs are you running? All standard rotary plugs don't require gapping.
Coochas
44
Nov 5, 2019 11:08 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
