Transmission rattle???
Old Jan 19, 2007 | 01:15 PM
nopistons3's Avatar
I just put a new rear main seal, clutch, slave cylinder, throwout bearing, pressure plate, bearing cover gasket, and input bearing seal, and when the clutch is depressed it makes no noise... when i let off of the clutch in nuetral it rattles?? Could it be the throwout bearing, or the input bearing??
Old Jan 19, 2007 | 01:30 PM
blwfly's Avatar
kiwi from downunder..
you didnt replace the piolt bearing? oh ur callin it the input?
i dont belive the tob can make a rattle noise maybe a wirring
check the shifter housing usally that needs transmission fluid myn ratled all the time
Old Jan 19, 2007 | 02:33 PM
83rx7boy92's Avatar
wierd
Old Jan 19, 2007 | 02:39 PM
josh...just josh's Avatar
The TII will live again
my clutch does that to, more of a growl. I was thinking maybe clutch drag, like from a warped flywheel or a bad pressure plate, but you changed that. I wish I knew man
Old Jan 19, 2007 | 03:58 PM
t_g_farrell's Avatar
Waffles - hmmm good
Do you have a short shifter? Those are known to rattle.
Make sure you tighten down the shifter into the tranny properly, maybe its loose.
Pilot bearings make noise with the clutch in when they are bad ottherwise they aren't doing anything when the clutch is engaged.
Old Jan 19, 2007 | 04:06 PM
trochoid's Avatar
Old Fart Young at Heart
Did you lube the input shaft, to bearing and clutch fork?
Old Jan 20, 2007 | 10:09 AM
sgieldon's Avatar
Cool
nopistons3;
Chime in anytime now to the questions asked above so we can help you???
steve
Old Jan 21, 2007 | 08:54 PM
adidas_720's Avatar
The throwout bearing is the problem, i lost the 2 spring clips that hold the throwout bearing to the fork. so the throwout bearing is movin back n forth between the fork. Does anybody have any spare clips??? doubt it im in michigan though
Old Jan 21, 2007 | 09:24 PM
Rx-7Doctor's Avatar
Wait, did you change forum names? Or do you just suffer from MPD?
Old Jan 21, 2007 | 09:57 PM
adidas_720's Avatar
uhh what is MPD
Old Jan 21, 2007 | 10:08 PM
blwfly's Avatar
major psychological damage
thats a harsh one doc
Old Jan 21, 2007 | 10:23 PM
adidas_720's Avatar
well im sorry we cant all be RX7 doctors now can we nobodys perfect
Old Jan 21, 2007 | 10:29 PM
rolfs_7's Avatar
i play with my wankel
well...maybe u should try??? JK so have u got it fixored?
Old Jan 21, 2007 | 11:04 PM
Rx-7Doctor's Avatar
Don't get your undies in a bunch. It stands for Multiple Personality Disorder.
It is a joke
Are you the same person as the thread starter?
Old Jan 21, 2007 | 11:24 PM
blwfly's Avatar
humor is not expressed well in wrighting
Old Jan 21, 2007 | 11:55 PM
chedda_j's Avatar
yeah i got all confused there, thanks for clearing things up there doc. Funny ****
Old Jan 22, 2007 | 08:14 AM
nopistons3's Avatar
yeh, this is my 1st rx7.
Old Jan 26, 2007 | 02:01 PM
nopistons3's Avatar
transmission fixed...flywheel wasnt properly seated. learn somethin new every day. car runs sweet now.
MILOS7
Oct 9, 2015 02:19 AM
rxlevi7
Sep 26, 2015 07:28 AM
