n00b question... what can i rev my motor to w/o problems?
Old Jan 19, 2007 | 01:04 AM
tkit213's Avatar
Level** 13b
with the mods in my sig, what do you guys think i can rev my motor to w/o anything bad happen? i was told 7600 to 8 grand. i have a stock tach.
this is my first rx7 ive ever OWNED and its modded. i used to drive my brothers 10th anniversary.
anyways, lmk. thanks guys.
Old Jan 19, 2007 | 01:48 AM
trochoid's Avatar
Old Fart Young at Heart
Unless you have performed the internal mods diring the rebuild, i.e., oil mods, lightening and balancing, stay under 8k for engine longevity. It wouldn't hurt to put it on a dyno to find where the powerband lies.
Old Jan 19, 2007 | 03:04 AM
DriftFB's Avatar
Reno Rotary.
None of your mods listed would affect the engine redline. If, like Trochoid said, you modified the internals some, go for it. If not I would stay to the factory 7K.
Old Jan 19, 2007 | 03:13 AM
Rotary13B1's Avatar
Rev it till it BEEPS!!!!!, then shift!
Old Jan 19, 2007 | 04:35 AM
trochoid's Avatar
S5 NAs have lighter rotors, hardened stationary gears and a factory redline of 8k. Without oil mods and balancing, I'd stay with 8k. I suggested the dyno due to the porting. Powerband will be little different than a stock S5 and more tuneable with the Haltech.
Old Jan 19, 2007 | 07:16 AM
Nate83SA22's Avatar
Wellington Rotary
yea i have a bone stock 83 Fb base model 12a 5spd. where should i shift? the motors got 178K miles on it and the seals between the housings are starting to go. I know this thanks to some help from you guys and other members by cleaning off the oil between the housings letting it run and checking for oil again. also the my beehive oil cooler's o rings have gone because I noticed decent amounts of oil on the far back drviers side housings under the oil cooler. ummm. It's got the stock carb....Rasts Nest...Thermal Reactor...and the clutch is going ummm.....i wanna know a safe rev to shift at that wont hurt the rear end Cause i was told that the drumbrake rear end is the one major weak link the cars driveline....and also a rev that wont put any more excessive wear on the housing oil seals...and most importantly since the car has the original flywheel and clutch on it (178K miles) I want a rev that is safe enough to where i don't have to worry so much about the flywheel coming up through the floor and cut my legs or head or a valuble limb off.....Even though it's worth losing a limb since I was actually able to find and buy my dream car....!!!!!
And if it's any more help I live in West Palm Beach, FL
Old Jan 19, 2007 | 07:28 AM
clbsinvaders's Avatar
www.ohiorotaries.com
Drive easy. Don't drive hard until you can get a rebuild. If this is your DD, or even your fun car, take it easy. Get a rebuild. Shift at 2500-3000. Max milage and takin it easy on the car.
Old Jan 19, 2007 | 07:29 AM
Nate83SA22's Avatar
Wellington Rotary
what would you recommend for a rebuild kit should i just get gaskets and seals and springs if it needs it..
Old Jan 19, 2007 | 07:49 AM
rotariesrule's Avatar
shift at 7200 don't go any higher, there isn't anymore power higher than that anyway.
Old Jan 19, 2007 | 08:07 AM
JKM's Avatar
JKM
Nate: you can get rebuild kits Mazdatrix or Atkins Rotary. Dan Atkins posts here frequently, so I would say give him your money
Old Jan 19, 2007 | 08:15 AM
Aye, support Atkins, both know what they're doing but the customer service is unmatched by atkins, because as metioned, they post here and can get back to you quickly.
Old Jan 19, 2007 | 08:38 AM
Yellow '79's Avatar
ERIC
i saw a vid of a guy driving an S4 all the way to 8k through a few of the gears
Old Jan 19, 2007 | 11:04 AM
Rx-7Doctor's Avatar
You are hijacking this mans thread Newbie. Now go and get some oil cooler O'rings, dump some Lucas oil stabilizer in the crankcase, put a new clutch setup in there and drive it until it no longer runs.
Oh, and if you have more questions, please start your own thread.
Old Jan 19, 2007 | 11:58 AM
tkit213's Avatar
Level** 13b
haha THANKS. yeah ill just wait to get it on the dyno for that powerband i guess. just have to see.
Old Jan 19, 2007 | 12:20 PM
876portturbo's Avatar
getcha brap on
Goodness, thats a pretty awesome 7 to start out with, im jealous J/k
Queppa
Nov 18, 2024 03:47 AM
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
incubuseva
14
Sep 3, 2015 12:37 PM
elfking
Aug 19, 2015 09:48 PM
bb6guy
Aug 12, 2015 03:29 PM
