Corksport Silencer Rattle
Old Jan 18, 2007 | 08:51 PM
ohayou88's Avatar
So I bought the corksport silencer to quiet down the ehaust a little bit. I really like the way it sounds now when i cruise and what not.
But It is annoying when i first start moving the car it rattles but after about like 1200-1500 rpm the rattles dissapears and from then on it doesn't rattle.
I have tigthened it down as much as i could with the wrench and hex key. It still rattles what can I do to make the rattling go away?
Thanks in advance for your help.
Old Jan 18, 2007 | 09:15 PM
Noel Caraballo's Avatar
taking it off obviously theres no way to stop it. I put mine back in the box it came in
Old Jan 18, 2007 | 10:06 PM
bryanfc's Avatar
drill another hole in the silencer and cannon, and put a nut and bolt on as well?
Old Jan 18, 2007 | 10:39 PM
ohayou88's Avatar
yea that would the best solution probally... anyone else got anymore input
Old Jan 18, 2007 | 10:49 PM
Valkyrie's Avatar
Put a band of max-temp RTV (liquid silicone gasket marker) around the silencer, let it dry (takes several hours), then put it back on... if you made it just the right thickness it should stop the rattling (figure out how big it needs to be).
Old Jan 18, 2007 | 11:10 PM
bryanfc's Avatar
If you do that make sure its HI temp stuff..
breakfast
Sep 20, 2015 07:06 PM
Rotospectre
Sep 13, 2015 11:22 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
