Wastegate Porting
Old Jan 14, 2007 | 11:56 AM
toplessFC3Sman's Avatar
Wastegate Porting
Well, with the engine out, i got the chance to do a bunch of smaller projects i've been meaning to do, such as cleaning, wiring & grounding, and wastegate porting. This was all done with a dremel, using the orange grinding wheels. I still need to weld a larger washer to the actuator arm, thats gonna happen when im back at school with access to a welder.
Once its back together, I'll post up about the (hopefully) lack of boost creep.
Attached Thumbnails Wastegate Porting-mvc-001l.jpg   Wastegate Porting-mvc-003l.jpg
Old Jan 14, 2007 | 03:05 PM
Aaron Cake's Avatar
Engine, Not Motor
Seems kind of small to me. It looks like it's only slightly bigger then the stock flapper valve. You can go much larger.
http://www.aaroncake.net/rx-7/s4wastegate.htm
Old Jan 15, 2007 | 04:36 AM
NZConvertible's Avatar
I'm a boost creep...
Yep, too small... Plus it needs a lot more back-cutting.
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/serious-s4-wastegate-porting%85-343788/ (scroll down to post #15 for reposted pics)
Shainiac
Jul 17, 2019 02:20 PM
Ian_D
Oct 14, 2015 12:31 PM
