? 1980 Alt.?
Old Mar 12, 2002 | 08:42 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
? 1980 Alt.?
ok i know the 79 had a external voltage reg... does a 80? a friend needs a new alt. he over tightened the belt and the bearing is FRIED. if its a internal reg. then ill slap on a extra 83 alt i have if not i guess weell have to find a 80.
Thanks
David
Old Mar 12, 2002 | 09:35 PM
mar3's Avatar
Administrator
Mine was not externally regulated...it's a Colorado '80 that was originally an auto tranny car...
Old Mar 12, 2002 | 09:55 PM
mar3's Avatar
Administrator
I'm hoping it wasn't modified previously for it to be that way or I may be misleading you...
Old Mar 12, 2002 | 10:29 PM
peejay's Avatar
Old [Sch|F]ool
My '80 also had internal regulator. Later alternators are a direct swap.
Old Mar 12, 2002 | 11:46 PM
riffraff's Avatar
smog nazi destroyer
i never swapped my alternator, so i am running an 80 in my 79. is this going to cause any problems (like the car not shuting off with the key).
should i through on the 79 instead
Old Mar 13, 2002 | 09:55 AM
hanman's Avatar
The 80 has an internal regulator. I would guess that you are going to have to do some wiring removal and possibly some rewiring. You are going to replace the external regulator with an internal. I would take a look at the wiring diagram for more info.
If you are going to all that trouble I think that I would find a used second gen alt and install that, it is a good upgrade.
hanman
Old Mar 13, 2002 | 02:02 PM
riffraff's Avatar
smog nazi destroyer
well my goal is to swap something in that willnot give me trouble, but i will look into the possibility of a second gen one. how involved is that swap?
Old Mar 16, 2002 | 12:45 PM
mar3's Avatar
Administrator
Can't believe I missed this...it's as easy as this once you've switched the car's wiring to an internally regulated alt set-up...
that 'ol alt conversion diagram again!!
I'm getting some serious mileage outta that one!
Old Mar 16, 2002 | 12:48 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Later up till 88, then you have to simply change the wiring a little
Mar3 posted a diagram somewhere
MIKE-P-28's Avatar
**** sorry, meant to hit edit
Coochas
44
Nov 5, 2019 11:08 PM
jim_chung
1st Gen General Discussion
Oct 4, 2015 09:09 AM
FC3S Timmy
Oct 2, 2015 08:08 AM
