HELP car wont start need HELP ASAP
Old Jan 13, 2007 | 12:40 PM
TheSTIguy's Avatar
i just put the top down witout the car being on then when i go to start it notting the lights wont come on on the dash or anything is there anyway to fix it? it was driving fine yesterday
Old Jan 13, 2007 | 12:45 PM
Icemark's Avatar
what does the voltmeter on the dash say when you turn the key on?? Anything???
If nothing, you have a disconnected or bad battery.
If it shows less than 12.6 volts, you have a bad battery
Old Jan 13, 2007 | 12:47 PM
TheSTIguy's Avatar
it doesent show anything notting works no dahs liughts no notthing but i just changed the battery
Old Jan 13, 2007 | 12:49 PM
Icemark's Avatar
Did it work at any point after you changed the battery?
Old Jan 13, 2007 | 01:06 PM
TheSTIguy's Avatar
i even changed it to the old battery still notting it was working fine yesterday started right up now no lights no notting works can anyone please help me out
Old Jan 13, 2007 | 01:17 PM
Icemark's Avatar
Get a multi-meter and read the voltage on the battery.
Chances are you just don't have something tightend down, but you need to rule out the battery being bad first
Old Jan 13, 2007 | 01:30 PM
TheSTIguy's Avatar
the battery is in the box thing but i dident put the tie down stuff on it. can the car be flooded?
Old Jan 13, 2007 | 01:45 PM
Needa13b's Avatar
'86 N/A Phone Dials
It depends on what you mean by, "flooded."
If you mean something like - your car started fine, you turned your car off, then put your top down, and then you received 10" of rain, on frozen or saturated land. Then that might be causing a problem.
If you mean your engine is flooded with gas, that would be a totally irrelevant problem.
-Do what Icemark said and find out your battery's condition.
-Alternately, most auto parts stores will "load test" your battery for free.
If your battery has an Open Circuit Voltage of 10V, and your battery has the capacity to run a wrist watch, you should still see a light or two flicker when your ignition is set to run. This situation would be a bad battery.
If you get your battery checked out and it is fine, and NOTHING turns on when your key is set to run, your ignition switch is not connected to your battery somewhere.
Old Jan 13, 2007 | 01:51 PM
TheSTIguy's Avatar
dammit i just bought this battery 2 days ago and i was suppost to get my new exhaust today =(
Old Jan 13, 2007 | 03:04 PM
TheSTIguy's Avatar
could i have blown a fuse? i charged my battery for like 30 mins and still notting
Old Jan 14, 2007 | 01:30 PM
Needa13b's Avatar
'86 N/A Phone Dials
Could have. They are right by the battery, easy to check. I do not know for sure if any fuses under the dashboard would affect this. I would check your main fuse box first, (the one by the battery).
Also, check your battery. I know you charged your battery for 30 minutes, but at what rate? A fully discharged battery, (OCV ~10V) can take 5-6 hrs @ 10 amps to fully charge.
Did you charge your battery while it was still connected to the car? Assuming everything is hooked up correctly, you should be able to turn your ignition on (don't try to start) and lights will come on. Don't leave your ignition on for more than a few seconds, since that will be as long as you need to see if it worked or not, and the charger is most likely not designed to charge and run your electronics for more than 20-30 seconds max.
Some chargers do have a "jump start" function, which basically provides your battery with a boost in voltage for maybe 5-10 seconds of cranking. Then you have to let the charger sit for 2 minutes to recover.
gtcd
30
Aug 19, 2015 02:44 AM
ashleymiche
Aug 14, 2015 12:59 PM
