Oil for racing?
Old Jan 10, 2007 | 10:47 AM
Prod's Avatar
Oil for racing?
What weight would be optimal? (for a 13b N/A)
Old Jan 10, 2007 | 11:16 AM
bean13's Avatar
i use 15-50 mobile one with the OMP removed. Cheaper than the race type oils and every bit as good if nto better in my opinion, but oil has as many opinions as there are about Iraq......
Old Jan 10, 2007 | 12:03 PM
wrankin's Avatar
Old Rotary Dog
What sort of racing? On a road course where you will see longer periods of high rev use, go with one of the good quality ##w50 multiweights (synthetic or dino, your choice). Make sure you warm up the car well before getting on the track. Change oil frequently.
-b
Old Jan 10, 2007 | 12:10 PM
bean13's Avatar
i guess i just assume road racing, synthetic all the way
Old Jan 10, 2007 | 12:11 PM
Whizbang's Avatar
Respecognize!
i premix and use 20w-50 synthetic
Old Jan 10, 2007 | 02:58 PM
bean13's Avatar
i use 2 cycle oil to premix....its ment to burn. Synthetics supposedly dont burn and carbon up a rotor...or so ive heard, never seen on exereinced first hand.
Old Jan 10, 2007 | 03:59 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
i use mobil-1 15/50, change the oil and filter after every weekend.
Old Jan 10, 2007 | 05:49 PM
Quicker10u's Avatar
A four-rotor team I know uses Valvoline Synpower 20-50 and won their class at the 24 hours of daytona with it, so I know that works..
Old Jan 12, 2007 | 08:39 AM
speedturn's Avatar
I have tried a half dozen different oils in the last decade, and now I stick to Valvoline VR-1 oil in the 20w-50 weight for my road racing 13B peripheral port motor. The Mobil1 is good stuff, but the Valvoline seemed to maintain 5 psi higher oil pressure after sustained operation above 8000 rpm - I don't mean shift at 8000 rpm, I mean don't let it drop below 8000 rpm in road races. I think the Valvoline has better anti-foaming additives. Foam (little air bubbles entrapped in the oil) is a problem with wet sump rotaries staying above 8000 rpm.
Old Jan 12, 2007 | 07:35 PM
cpa7man's Avatar
Racing is life!
Dam, that is some serious ****! Most of us shift at 8400 or so. I knew I liked VR-1 for a reason. I've run the Amsoil 20/50 racing and like it as well. I would love to drive a PP. If you check back here I'd be curious to know when the **** light goes off?
Old Jan 13, 2007 | 01:43 PM
John Magnuson's Avatar
20W-50 Idemitsu Synthetic has been working fine for me. No need to disable the OMP either.
Old Jan 13, 2007 | 02:18 PM
speedturn's Avatar
I normally shift about 9000 - sometimes I will run 5th gear out to 9300 if I am geared a little too low for the track I am at. With an naturally aspirated road race rotary, max performance is obtained with a very close ratio transmission that does not let the revs drop very much when shifted.
Old Jan 13, 2007 | 06:02 PM
cpa7man's Avatar
Racing is life!
Very nice. I'll bet those are pretty conservative shift points as well.
You said it about the tranny - I sure need a close ratio transmission. A friend build me a semi close ratio using 626 gears, but I'm in need of a comp box for sure.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
sYnth.
Aug 19, 2015 06:27 PM
