Is this possible?
Old Jan 3, 2007 | 12:36 PM
topaz's Avatar
Greek Geek
Is this possible?
Can a GReddy TD06SH-25G with 4x850cc injectors with stock fuel rails, at 15psi put down ~520bhp? (around 440whp)
is it possible?
Old Jan 3, 2007 | 03:14 PM
fastrotaries's Avatar
W. TX chirpin Monkey
Off the top of my head...I'd say no.
Old Jan 3, 2007 | 03:45 PM
dubulup's Avatar
development
http://www.maxcooper.com/rx7/how-to/...tem/calcs.html
here is a good site to get estimates...
Old Jan 3, 2007 | 10:32 PM
Poweraxel's Avatar
no
Old Jan 3, 2007 | 11:20 PM
I'd say nope.
Old Jan 4, 2007 | 04:44 AM
RETed's Avatar
The turbo should be able to do it.
What about fuel rail pressures?
If it's bumped up a bit, then it is possible.
-Ted
Old Jan 4, 2007 | 10:26 AM
topaz's Avatar
Greek Geek
-Ted
Fuel rail is stock and I don't remember the fuel pressure (besides that there is an FPR in the circuit).
But with 4x850cc injectors? Even at 100%?
At 15psi?
Old Jan 4, 2007 | 10:30 AM
charlies7's Avatar
3rd rotors a charm
just upgrade the secondaries and be safe...go with 1680's
Old Jan 4, 2007 | 12:35 PM
Rocking Rotary's Avatar
The fuel isn't the problem its the turbo. Its not going to make near that power at 15psi.
Old Jan 4, 2007 | 02:31 PM
adictd2b00st's Avatar
boost > *
yea i'm gonna have to agree with them and say no
Old Jan 4, 2007 | 03:01 PM
mr2foryou's Avatar
600+rwhp club member
Same here. No
Old Jan 4, 2007 | 04:50 PM
topaz's Avatar
Greek Geek
well take a look at the dyno. Torgue is ~59kgr! and bhp is ~500@6300. The dynoshop had to stop the test because it was already too late... And the exhaust could wake up a whole neighborhood.
anyway, to these numbers look possible?
Old Jan 4, 2007 | 11:03 PM
mr2foryou's Avatar
I guess we stand corrected. Nice. I wouldn't have thought that turbo would do it. Is this dyno sheet of your car?
Old Jan 5, 2007 | 12:40 AM
topaz's Avatar
Greek Geek
Nope, not mine. A friend's. Just wondering... cause I think the 4x850cc might be not enough.
Old Jan 9, 2007 | 04:03 PM
boost > *
makes sense now, thats on a dynapack
Old Jan 9, 2007 | 04:36 PM
topaz's Avatar
Greek Geek
What do you mean? Is it unreliable?
Old Jan 10, 2007 | 09:10 AM
boost > *
not unreliable, they just read higher than roller style dynos. in comparison, a mustang dyno will read the lowest. still solid numbers tho, #'s are overrated anyways as long as it drives good and the curve is smooth is what matters
Old Jan 10, 2007 | 09:30 AM
Where did you hear that? I was told my a dynapack owner/operator that they tend to read a bit lower than dynojets, he claimed that numerous times customer cars would put down a higher rwhp figure on a dynojet after they left his dynapack. Not sure about the validity of that, but he seemed pretty matter-of-fact about it.
Old Jan 10, 2007 | 10:28 AM
topaz's Avatar
Greek Geek
Which is the most reliable dyno?
Old Jan 10, 2007 | 04:40 PM
EvilJester's Avatar
Apply clever comment here
not to be argumentative, but dose it matter? Are you going to notice a 1% to 2% difference between them? Like adictd2b00st said, numbers are overrated.
Old Jan 10, 2007 | 08:00 PM
boost > *
well, he could very well be right, based on what he's using for correction factors. thats why its kinda hard to argue dyno numbers, theres too many variables i'm just saying, TYPICALLY from what i've witnessed a dynapack will read higher.
case in point about correction factors (and i know this is VERY extreme) when i had my car on the dyno last (this particular one was a dyno dynamics) we were getting REALLY good numbers in relation to boost levels..... and then the owner of the shop remembered that he had set the correction high for a customer car who dyno'd ~750whp and wanted a dyno chart to "get his friends" that read 1000whp, and forgot to turn it back down after the fact, and my car happened to be the next one to use the dyno.
Old Jan 10, 2007 | 08:14 PM
Gorilla RE's Avatar
GorillaRaceEngineering.co
what kind of port work?
