Oil cooler replacement question
Old Jan 2, 2007 | 11:39 AM
jkstill's Avatar
Searching for 10th's
My FD is getting new oil coolers this week.
I had planned on draining the oil to do this, but it occurred to me that this may not be necessary.
The lowest hose is on the front cover, and I don't believe oil will reach that level.
So it should not be necessary to drain the oil to pull out out the stock oil cooler setup.
Correct?
Or not?
Old Jan 2, 2007 | 11:46 AM
DamonB's Avatar
Yep. You'll make a mess with what remains inside the lines regardless, but the pan's contents won't somehow empty. Especially if you have the front end jacked up slightly.
Old Jan 2, 2007 | 12:02 PM
jkstill's Avatar
Thanks for the info
Thank, it didn't appear necessary.
Save some oil too, as there is only 50 miles on the new engine so far.
Old Jan 3, 2007 | 12:00 PM
qwester007's Avatar
Road Racer
you could change the oil to make sure there are no contaminents from the rebuild. Remember- oil is cheap.
Old Jan 3, 2007 | 02:22 PM
jkstill's Avatar
Oil changed
Thanks, but that was done before I got the car back.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
