South RX-7 Forum Serving Texas, Oklahoma, Arkansas, Louisiana, Mississippi
Where can I get a compression test done? N.O. area
Old Dec 29, 2006 | 04:27 PM
EZMONEY's Avatar
I have 2 13b engines and I just need to get one tested. The other one I think is blown, it doesn't look great. Also post if you know how much it will cost me.
Thanks in advance!
Richard
Old Dec 30, 2006 | 03:06 PM
stevie1020's Avatar
Gig a Giddy Go
where do you live ill see if i can get the tools together to help you if not try CAT5
Old Dec 30, 2006 | 05:39 PM
EZMONEY's Avatar
I live in Harahan.
Old Dec 30, 2006 | 07:35 PM
recon fd's Avatar
semper Fi
I am not quite sure, but when you find out let me know because I want to go with you to test mine at the same time.
thanks,
-j tizzle
Old Dec 31, 2006 | 02:46 AM
EZMONEY's Avatar
No problem. You have an extra one or the one in your car?
LOL @ j tizzle
Old Dec 31, 2006 | 10:54 AM
hondahater's Avatar
spending too much money..
so it's not in the car? thats going to be hard to test compression with out it in a car or on some sort of test stand where it can at least crank at 300rpm. If it is in the car then why don't you just get a piston compression tester from advance and test it yourself?
Old Dec 31, 2006 | 02:31 PM
recon fd's Avatar
semper Fi
LOL @ j tizzle
the one in there.
Old Dec 31, 2006 | 03:08 PM
EZMONEY's Avatar
ohhhh, I didn't know that. Maybe I'll just tear apart my other one and see how bad it is inside myself. If anyone wants to help tear down a kinda rusty 13b, Let me know. Airtools would be awsome BTW,lol
Old Dec 31, 2006 | 03:19 PM
hondahater's Avatar
if I was close I would but I'm on the other side of louisiana. Good luck and don't worry air tools are not really needed, Well besides the flywheel bolt. Also be sure and rememeber how all the front cover stuff goes on. Other than that it's real easy, like putting a double decker sandwitch together
Old Dec 31, 2006 | 04:33 PM
EZMONEY's Avatar
LOL, I've put a few DD sandwitchs together so I might be able to get it. Yeah the crank bolt is giving me problems though. I haven't even made it the flywheel yet,lol.
Old Jan 1, 2007 | 04:46 PM
hondahater's Avatar
IF you have a long breaker bar then you can use that for the front bolt as long as someone can hold the flywheel nut from turning in the back (if you have a big enough socket for it) or you can get one of those flywheel holder tools from mazdatrix witch would make things alot easier. Here one of these at 36 bux http://www.mazdatrix.com/getprice.asp?partnum=49-22000 and one of these at 23 bux http://www.mazdatrix.com/getprice.asp?partnum=49-220NT should have you well on your way to opening that thing up.
Old Jan 2, 2007 | 02:03 AM
stevie1020's Avatar
Gig a Giddy Go
i can help ya when i have a day or to off if youd like
Old Jan 2, 2007 | 02:45 AM
EZMONEY's Avatar
Help is always welcomed. I don't know much about the 13b and what little bit I do know doesn't come in to play when I can't even get it apart, lol. You can call me pretty much anytime at 504-274-8958. I'll answer as long as I'm not doing something importent. If I don't answer then please leave a voice mail. Thanks
Richard
wickedrx2
The Bad & Fugly Members
Jun 10, 2021 06:28 PM
SCinfidel
Sep 8, 2015 05:36 PM
whinin
Sep 5, 2015 11:52 PM
