First time changing my rear brake pads
Old Dec 28, 2006 | 12:50 PM
MavrickFD's Avatar
All I have is a basic socket wrench and ratchet set with needle nose pliers. I failed my state inspection for worn rear brake pads and I'm low on cash so I decided to do it myself. All I'm worried about is putting the calipers back on and bleeding the brake system. Will I need any other tools?
Old Dec 28, 2006 | 12:58 PM
TailHappy's Avatar
Addicted to Track
More than likely. You're probably going to need a BIG socket wrench to loosen the bolts. They are going to be tight, and need to be put back tightly.
Also, you'll probably need to go to your local parts store and get the universal piston adapter (there's probably a proper name for that). The rear pistons rotate back in as opposed to just pushing back in like the fronts do. The adapter makes that a lot easier and keeps you from messing up the piston from trying to use a tool that doesn't fit.
I think that's about all that comes to mind assuming you have jacks/jackstands/lugnut wrenches, etc.
You shouldn't necessarily have to bleed the system as long as you don't loosen the bleeder. Though I always like to bleed the system while I'm in there since that's the easiest time to do it.
Old Dec 28, 2006 | 01:50 PM
jkstill's Avatar
Searching for 10th's
New brake pads will be much thicker than the old ones.
This means the piston will need to be screwed back into the caliper.
When doing that, you need to open the bleeder. If you don't open the bleeder, you risk damaging the master cylinder. There is a check valve in OEM MC's - opening the bleed screw is a necessary step when changing pads.
Old Dec 28, 2006 | 02:54 PM
amp's Avatar
amp
old yella
why do you need to open the bleeder...
relieve pressure from opening the master cylinder cap..
Old Dec 28, 2006 | 03:03 PM
nolimitniceguy's Avatar
yeah you dont need to bleed the brakes, just remove the master cylinder lid... be careful it might overflow when u press the pistons back in
Old Dec 28, 2006 | 03:07 PM
DigDug's Avatar
Registered User
I recently bought one of these at my local Advance Auto for pushing the pistons back in:
http://www.partsamerica.com/ProductD...tnumber=T71921
Sure beats my old plier method.
Old Dec 28, 2006 | 03:17 PM
yuichiror's Avatar
Sweet! And only ten bucks!
Hey Flynn, I'm off from tomorrow till Tuesday if you want to do the brakes this weekend.
Old Dec 28, 2006 | 03:24 PM
SINxSELEKTAH's Avatar
Punkrockin JUNGLIST
when you're screwing back the piston, just open up the lid to your filler, bleeding isn't necessary
Old Dec 28, 2006 | 03:27 PM
Sandro's Avatar
Follow these tips
http://www.fd3s.net/brake_job.html#REA
Better to open bleeder valves when retracting the pistons and avoid pushing back dirty fluid to the ABS system.
and this is the tool you need to retract the pistons
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Old Dec 28, 2006 | 05:08 PM
Punkrockin JUNGLIST
Originally Posted by Sandro
Follow these tips
opening bleeder valves would allow dirt to enter the pressurized brake system. especially since bleeder valves are covered with dirt. unless propperly cleaned, then it's a good way to start.
Old Dec 28, 2006 | 06:27 PM
Sandro's Avatar
Not sure what SINxSELEKTAH is trying to say...
Just to clarify:
- any fluid (including brake fluid) always flow from high pressure to low pressure
- if you open the bleeder valves first, there is no fluid flowing because the brake system is at rest and is not pressurized
- when you retract the pistons you pressurize the brake system and fluid will flow out of the bleeder valves - there is nothing to be afraid of - on the contrary it's a good time to get rid of old dirty fluid - just make sure to keep refilling the master cylinder to avoid level going to low and air entering the system
- if you don't open the bleeder valves and just open the master cylinder cap instead, when you retract the piston and pressurize the system, chances are that some dirty brake fluid will enter the ABS portion of the brake system, which is undesirable
In any event, it is good practice to bleed the brake system regularly - if you haven't done it in a while, you will be surprised how much black liquor will come out of those bleeder valves.
Old Dec 28, 2006 | 08:14 PM
amp's Avatar
amp
old yella
...Better to open bleeder valves when retracting the pistons and avoid pushing back dirty fluid to the ABS system..
its negligible.. unless of course you dont change fluids on schedule..
considerin its just to clear a pad.. most dont retract it far enough to be of any major concern..
of course its good practice to bleed at this time if you havent already done so..
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 17, 2015 09:36 AM
Marty RE
Aug 13, 2015 11:19 AM
