Car had trouble starting, then huge plum of white smoke.
Old Dec 27, 2006 | 03:03 PM
Specter328's Avatar
NASA TTS Build
I was trying to start my car and after about two minutes trying to get it turned over and giving it gas it started. Right when it started a huge amount of white smoke shot out the exhaust and it idled at around 3000rpm fairly rough and then it went to 1200 still idling rougher then normal and now its at 1100rpm idling normally with no smoke. What could this have been from?(I started the car yesterday to move it, and it is stock)
Old Dec 27, 2006 | 03:08 PM
jd to rescue's Avatar
My guess is when you made the short move of the car, you flooded it. Rotaries are notorious for flooding when started up, run briefly and then shutdown.
How did it start after you had this episode?
Old Dec 27, 2006 | 03:16 PM
Specter328's Avatar
NASA TTS Build
It started fine yesterday then today it just wouldn't turn over easily.
Old Dec 27, 2006 | 03:30 PM
Once you got it started today, however, have you tried to start it since? If so, how did it start the second time?
Old Dec 27, 2006 | 03:35 PM
Specter328's Avatar
NASA TTS Build
I restarted it and it fired right up, no smoke.
Old Dec 27, 2006 | 03:37 PM
Then it was probably flooded. Happy motoring!! Make sure in the future that you don't start up and shutdown too rapidly.
Old Dec 27, 2006 | 03:42 PM
^^If it becomes a regular problem in the future, then you may have leaky injectors.
Old Dec 27, 2006 | 03:55 PM
katinkid's Avatar
Dont worry bout it to much, mine does this almost everyother start!
how many miles does urs have on it, if this is the first time chances are it was from the rapid start and shutdown, and start.
if it persists, you could have a coolant leak. mine started doin this after i boosted when it was cold, yah (my dumbass mistake)lol. anyways now i just have to fill it with coolant every week.
but almost positive it flooded itself a little.
if you happen to rapidly shut it off again. just hold down gas and turn over. than turn off. and start normaly.
Old Dec 27, 2006 | 06:59 PM
Specter328's Avatar
NASA TTS Build
The engine is a Mazda Reman with 30,000 miles on it, it wasn't a rapid restart, it didn't start on the first try.
Old Dec 28, 2006 | 12:19 AM
katinkid's Avatar
yeah if you do it again:
hold down gas, turn key, let engine crank for like 5 sec. this will clear the chamber.
than just start it.
Old Dec 28, 2006 | 07:49 AM
White94RX's Avatar
BMW Tech
worst case is bad coolant seal, leaked coolant into combustion chamber, then had to burn/push out all the coolant (white smoke, i.e. steam).
Old Dec 28, 2006 | 09:04 AM
telum01's Avatar
what he said.
Old Dec 28, 2006 | 09:15 AM
Whizbang's Avatar
Respecognize!
but if the car gets badlly flooded it usually makes serious white death until it burns off. (from all my experiences)
color of smoke is tricky.
torky007
Aug 17, 2015 05:14 PM
Junkee
Aug 15, 2015 01:57 PM
Marty RE
Aug 13, 2015 11:19 AM
